Same machine and model and same problem. It’s really irritating. It’s not the bobbin as the screen flashes worth the foot pedal. I’ll look at the tension but given how often it beeps and on so many different projects with different thread and tension it seems to be a fault of some kind... searching for a fix...
Hello I can read your full problem but when it hapen unplug your foot pedal to see if the pedal is causing the problem here is a link for a original foot control replacement http://www.tvps.com/Products/Philips-LFH-0210-Foot-Pedal---New__PH-LFH-0210.aspx or just send your unit for service at Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
The foot pedal needs to be plugged in before the software is installed. Just uninstall the software (your files will be fine) and reinstall with foot pedal attached.
Make sure you are installing the Transcription version of the software not the Dictation version (Transcription version serial number starts with RTM and dictation starts with RDM). The foot pedal will not work with the dictation version of the software.
My dictation pedal for the Olympus AS-4000 used to work on windows XP, but I upgraded to windows Vista and and the foot pedal no longer works. I have tried it on another XP machine and it works fine, so it can't be the foot pedal.
I have downloaded a patch from the internet, but unfortunately this does not seem to have resolved the issue.
I have contacted olympus twice and they have been very unhelpful.
