GE Front load dryer just over year old. moved from one house to another. stopped working, DPH880EJMG checked door switch - good, checked 2 rear fuses. temperature, and moisture reading good. exhaust ok. error code 12 c switch, so replaced motor LG DPH24401 same as prior, Old motor c switch check bad would not come off start windings. reassembled - still same issues, press start will not start - just 2 beeps
Make this test: God bless you
- 45 -
Service Test Mode
The dryer control has a service test mode that can be utilized by the service technician in order to test
critical components and to access error codes. This test mode will help the service technician to quickly
identify failed or improperly operating dryer components.
Test Mode Description
t01 Model ID Verifi
es (or sets on new board) the proper model id.
t02 Error Codes Lists up to 10 control-detected problems.
t03 Software ID
Displays the software version number and the non-
volatile memory version number.
t04 Program Non-volatile Memory Test Control computes and compares the 16-bit CRC of
the non-volatile memory with the pre-computed
version stored in the non-volatile memory.
t05
User Interface
Control turns on all LEDs and the 7-segment display.
t06 Keys Continuity Verifi
es that all displays and buttons work.
t07 Outlet Thermistor Displays outlet thermistor temperature.
t08 Inlet Thermistor Displays inlet thermistor temperature.
t09
Moisture Sensor
Displays voltage read from the moisture sensor.
t10 Exhaust Detection Verifi
es status of the exhaust system.
To enter the test mode: To exit the test mode:
Disconnect the power for 30 seconds.
Reconnect power and within 30 seconds of
reconnecting power:
Press signal button.
Press delay start button.
Press delay start button. (Displays t01)
1.
2.
a.
b.
c.
d.
Press the power button during the test selection
mode.
Note:
A dryer left in the test mode will exit the test
mode after a period of 30 minutes
SOURCE: 196 degree non resettable thermal fuse
That is the thermal fuse. It must read closed for the dryer to work. You can connect the two wires together to check the rest of the system, but don't run it with them crossed for normal drying. Many times this is an indication that the high limit switch is sticking or the duct is clogged with lint causing a high temp situation.
Post back if you have any questions.
SOURCE: ge electric dryer. suddenly stopped working. Will
Hi Stv,
There isn't really major problem, but a problem.
You will need to unplugged your unit and take it apart. Are you handy?
If and when the unit is apart look at the motor and the fan exhaust and see if there is a coin or screw is jamming the motor or the fan
while you are in there you may want to clean it up,
That should be the problrm
SOURCE: ge front load dryer not
Hi, If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. check out this electric no heat tip... heatman101
hello Ron, would you be able to tell me how to enter into the test mode sequence on my LG DLE2350R dryer?
Thanks, Doug
