The different codes are telling you, there is a copyright protection on the sound or the video. Sometimes parts are protected, because it was intended for other use.
See the link to: Cinavia Messages Message Code 1
1. Insert the DVD disc into the computer's DVD-ROM burner drive. Click on "Burn files to disc" from the window that automatically pops up.
2. Type a name for the DVD disc in the "Burn a Disc" box. Click "Show formatting options" and choose a formatting option.
3. Choose "Live File System" to allow files to be copied immediately to the DVD disc, much like sending data to a USB flash drive or floppy disk. Live File System discs can only be read by Windows XP or later versions. Choose "Mastered" to have files be copied to the DVD all at once. This is the standard burning method; discs can be played back on any DVD-ROM drive.
4. Click "Next" to prepare the disc. Files can now be copied to the disc using the selected method.
If a CD is write-protected, it means that it is closed. Or possobly not formatted. [[CD-R stands for Compact Disc-Recordable and can be recorded only once. You may continue to add files until the CD is full as long as the disc is not closed (write-protected). You cannot delete, rename, rearrange, or alter the files or file structure on the CD after recording.]] Open CD: [[If a CD is open, it means that further information can be added to it. It is not write protected.]]
Closed CD: [[If a CD is closed, it is permanently write-protected. No further information can be added to the disc. Closing a CD is analogous to moving the write-protect tab on a floppy disc to the write-protect position. However, unlike floppies, you can only change the write-protect setting on a burned CD once. Once the disc is write-protected (closed), this setting is permanent.]] You can try this one:There is this program called sound taxi it is suppose to remove write protection. link is here http://www.soundtaxi.us/download.html
It is not the player you need to reset, it is the rental DVD's. They are encrypted with a code to limit the amount of time they can be watched, thereby protecting them from being stolen or not returned. Send them back to the rental company and rent the same movies again. That is your only solution. Your player will play whatever is put into it. I hope this helps.
if that is a copy of a blu ray movie you are trying to watch... when the copy was made the copyright protection was not removed before it was recorded.
Yes,
In the Disc Management options you should have the option to change whether disc protection is on or off.
Also, if you have one of the double-sided discs - they look like large computer floppy discs and can be inserted either way up into the machine - some of these have a "write protect" tab just like a floppy disc. Check to see if yours has one and whether it is set in the protect position.
