To create a partition from a new or newly formatted computer, make sure Windows is installed. Load any programs and drivers you would like to keep in case you need to back up to a previous version of your computer's settings.
Install your partition creation software; in this article we will use Norton Ghost. Before creating your partition, disable any anti virus and other scanning software.
Create your partition by going to your ms-dos prompt: from your Start menu, press "Run," and type "cmd" without quotations in the run dialog box. At the dos prompt, type "fdisk" without quotations, and choose option 1 (Create DOS partition or Logical DOS Drive). Set the partition size to 10 GB at press enter.
Open Norton Ghost and follow the instructions to create a recovery partition in the new partition you had just created. The process should take anywhere from one to three hours, depending on the size of the files you are going to back up.
Restart your computer. When done, open Norton Ghost to verify that the Recovery Partition was created.
Using the Recovery Partition:
1. Press [F9] during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click
Next.
4. Read the ASUS Preload Wizard messages and click
Next.
5. Select a partition option and click
Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other
partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates
Recover Windows to entire HD with two partitionThis option deletes all partitions from your hard drive and creates two
new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery
process.
Make sure to burn off your recovery DVDs as soon as you get you rsystem back up and running so that you have them in an emergency.
Perhaps you have deleted your D: partition accidentally.
