SOURCE: I'm trying to hook up my Acer Aspire x1700 to a
You can set the receiver to any source that uses a optical connection. Then make sure that whatever you select whether it be CD/DVD you also have the source connection set to optical too on the receiver setup menu.
That being said, after that is done you will need to set up the computer to output audio. That usually just involves changing the output mode on the computer and adjusting the levels...open the Acer audio managment application, choose the audio output mode to stereo or dolby digital and turn everything up on the computers level controls. Then, when you open whatever software you're going to use to play your discs you may also have to adjust the volume level there as well.
SOURCE: Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
SOURCE: I have a Yamaha HTR-5630 receiver. Can I add a
try use 1/4" stereo plug to two RCA plugs used with amplifiers and mixers
[img]http://www.mcmelectronics.com/images/product/icons/magnifier250.gif[/img]
use yamaha cd or aux input ..
SOURCE: My Yamaha HTR-5740 died on me leaving behind only
Most Yamaha remotes work on other Yamaha receivers. I would say yes because I had to do the same thing, and it works.
SOURCE: I have a yamaha htr
You can do it, you would just need a Pre-amp for the mic to work without major feedback. They range in price from 50 and up. An inexpensive PA system would be a better way to do this. You can find decent ones for personal use for under 300 that are well built and come with a mic. Check www.Zsounds.com, They have something for any price range. Hope this helps
