SOURCE: setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
SOURCE: Craftsman power drill - batteries wont recharge
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
SOURCE: 2006 buick la crosse when i
The noise from the power steering unit can be from wear,the only way to eliminate the noise,is to replace the unit.
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
