SOURCE: Panasonic PV-DV103D
This is actually a problem with the ribbon cable. When the tape is put in and the tape door is pushed shut it jars the internal ribbon cable. Years ago I found this tip online & it fixed it!
Quote
"Ok, here goes, I had the exact same problem on my pos Panasonic
pv-dv203d. After many times of taking it apart and many frustrating
calls to Panasonic, I've finally figured it out, I hope
it helps on your cameras.
Remove the bottom plate from the Camera (four screws, plus one near the LCD screen).
Pop off the bottom plate of the camera
Look at the ribbon cables carefully, and make sure they are all
snug in the plugs. The tape transport mechanism may move them out of
place."
Every now and then our will start to act up & hubby unscrews the bottom of the camcorder (Panasonic PV-DV203D), gently maks sure the ribbon cables are in place, replaces the bottom plate & it's worked for us every time. i hope this helps!
SOURCE: Lens Cap Warning & Gray Distorted Display
CCD Failure/Lens Cap Warning Error
JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 30th June 2009 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
