SOURCE: Have an Olympus Stylus 850
yes this is possible all you have to do is follow these instructions:
there is two ways to load pictures from your cam to pc:
step 1
youll need a card reader to put in the memory card to a usb port.
A.then the computer will recognize the device as a FLASH DISK/ REMOVABLE DISK.
B.some pc will automatically open once you inserted the card reader to the usb port "click open containing folder". if the pc does not open automatically open my computer and find the "falsh disk/removable disk" and click.
C.once inside find the DCIM folder this contains your pictures taken from your cam.
D. now you can choose a picture you like to be transfered or copy to your PC
E. save picture in a folder that you ca easily remember
step 2
need a usb wire to connect cam to usb port
A. attach wire from your cam to usb port/pc
B. your cam will show options choose storage data. the other options requires a software
C.same as step 1 from B-E
i hope i was able to help you! good luck!
SOURCE: i have an olympus stylus
This camera has a fixed lens and there is no way to change the aperture for the camera. It is a simple point and shoot model camera. The camera whether in Auto or Program mode will determine the best aperture and shutter speed to use based on the lighting conditions you are shooting in.
SOURCE: downloading pictures from my olympus 850 sw
As long as the memory card was not formatted it is possible to recover the images that were accidently erased,lost or corrupted. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost images.
Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
SOURCE: Need manual for Olympus Stylus 850 sw camera
you can download the manual here http://safemanuals.com/user-guide-instructions-owner-manual/OLYMPUS/STYLUS%20850%20SW-_F Please note that the user guide is in French
SOURCE: my camera olympus 850 SW
i don't have the solution but i experienced the same problem on my olympus 850sw
the images turns violet and the pixels are distorted
never see this kind of error ever a camera had
