Please this chart troubleshooting and fix it. God bless you
How to check automatic transmission fluid.
An automatic transmission depends on the transmission fluid for
transferring engine power to the wheels, shifting gears, lubricating
moving parts and cooling down the transmission. Check the transmission
fluid when your car is serviced and change it as recommended.
Different cars have different ways of checking the transmission
fluid level; some require the engine to be shut off (e.g. Honda), some
cars don't have a transmission dipstick at all and the fluid can only be
checked in a repair shop. Check your owner's manual for proper
procedure. This is how the transmission fluid checked on most cars:
After the vehicle was driven for a while to let the
transmission fluid warm up, place your vehicle on a level ground. Set
the parking brake. Make sure the transmission is in "P" (Park) position.
Leave the engine running. Find the automatic transmission dipstick
(your owner's manual will tell you where it is located). Pull the
dipstick out.
Wipe the dipstick off with a clean lint-free rag. Insert it
back fully. Pull it out again and check the fluid level. A
transmission fluid expands when warmed up, so if the car has been driven
for a while (20-30 minutes), the transmission level should be between
"HOT" marks. If the vehicle is cold, the level should be between "COOL"
marks.
Check the fluid condition: a very dirty fluid with strong
burnt smell is a warning sign of transmission problems. Normally the
automatic transmission fluid should be clean and transparent, asThe automatic transmission is shifting oddly and - transmission-fluid3.jpg
On most cars the new transmission fluid comes red (photo on
The automatic transmission is shifting oddly and - transmission-fluid5.jpgme it becomes brownish, as in the photo below.
This is how the synthetic transmission fluid looks after
two years of driving - it's still clean and transparent. If
your fluid looks very dark or dirty, check your owner's manual, maybe
it's time to change it. Some manufacturers require to change the
transmission fluidThe automatic transmission is shifting oddly and - transmission-fluid4.jpgles others specify that you
never have to change it - check what's your car owner's manual says.
If the transmission fluid level is low, you can top it up,
but be careful not to overfill it. Overfilling the transmission can
cause problems.
It's very important to use only specified transmission fluid
type - check your
owners manual or simply visit your local dealer, they always
have proper transmission fluid in stock. Incorrect fluid type can
damage your transmission. How to top up the transmission fluid: Using a
thin funnel, add a small amount of the fluid through the dipstick pipe.
Wait for a few minutes - let the fluid drain down. Recheck the level
again. Don't overfill
SOURCE: 1999 Blazer 4wd - Trans jump's HARD to 2nd gear on takeoff
shifts off electric servo controlled by cars computer , see trans guy you can trust could need service ,oil and filter changed or part , like i said see one you can trust .
SOURCE: transmission automatic slips in higher gears
This sounds like the main clutch pack has failed, is the fluid dirty?
SOURCE: 1997 Suburban 4x4 5.7L Transmission whines until it shifts
You rear planetary set is worn from a restricted cooler.
I should also note that before this issue arrose the struts, and k frame were replaced.
