Follow this steps and fix it.
God bless you
Check power problems if the console on the elliptical
machine does not light up. Make sure that the plug for the machine is
secure in the outlet. If it is plugged in, ensure that the outlet is
receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the
elliptical machine. Because different adapters are able to handle
differing amounts of energy, the wrong adapter will not transfer
electricity like it should. If the adapter is pinched or damaged, this
could also alter its effectiveness.
Make sure the correct adapter is being used if the
resistance settings seem to be too hard or too easy. If the correct
adapter is being used, reset the machine. To reset the machine, either
switch the "On/Off" button or unplug the machine from the wall. Doing
this will allow the device to reset itself to the default resistance.
Turn on or plug the device back into the wall and retry all of the
levels of resistance.
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: Stuck Key Error Message on Life Fitness F3
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
SOURCE: Life Fitness T5i treadmill, stops without warning
hi
try to adjust and clean speed sensor and wheel on the motor
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
