SOURCE: KENMORE DISHWASHER WATER DOESN'T SPRAY.
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely
replace it. It's usually located behind the lower access panel on the left or right side. It's the device
with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two
wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor."
Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills
the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised
position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
SOURCE: I have a Fridgidaire Ultra Quiet I dishwasher. The
Remove the 2 screws that hold the bottom kickplate on to ensure that the wash motor has not come unplugged. It happens more than you'd think. If it is plugged in, if you have a multimeter, just check if you have 110v to the wash motor...if you do, then the motor has failed and should be replaced
SOURCE: No pressurized water spray
internal pump failure....check that it is not blocked ...the water supply hose only fills tank then the pump pust pressurised water to the spinning arms.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
