There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges.There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges..And keep up the good work you are doing for the country...
SOURCE: casio telememo 30 syncronising analogue and digital time
To set the analog time to match the digital time...
There are 4 buttons: top left=A, top right=B, lower left=C, lower right=D
Get the watch in timekeeping mode (where it shows the digital time or date)
Press C six (6) times
Hold down A until the current digital time begins to flash
Press D repeatedly to advance the analog time, one minute at a time.
If you need to advance the analog time at high speed, HOLD D DOWN.
To return to regular timekeeping mode, press C
Set the digital time so that it matches the analog time, since you can reset the seconds easily.
SOURCE: changing analog hands / time function due to daylight saving time
Download the manual from
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
SOURCE: I replaced the battery in my Casio telememo 30 and
You can try turning the back around 180 derees or you may have lost the little spring inside of the movement when you replaced the battery.
SOURCE: How to release the battery clip on Casio Databank DBC-1500?
I would get it repaired by a Casio technician it will save a lot of headache. www.casiowatchrepair.com
