Sony Ericsson W200i Cellular Phone Logo
Julie Posted on Sep 30, 2013
Can I use another phone provider sim card in phone
What site can I go to get a puk code
PUK number can only be obtained from the service provider's SIM card.
Remove the SIM card from the phone.
Record the serial number (MSISDN / ICCID) available on your SIM card.
Contact your service provider SIM card (or via online).
Give information that you will be asked for the PUK number.
Customer Service from SIM card service provider will ask a serial number (MSISDN / ICCID) of your card (instead of your phone number), and will provide its PUK numbers.
Insert the SIM card, turn on the phone, and enter the PUK number.
Filling the PUK numbers should not be any more than 10x. Because if that happens, your SIM card can not be used at all.
Sep 03, 2015 • Cell Phones
tip
Phone displays "SIM card rejected" or "SIM card unaccepted".
The SIM (subscriber identity module) card is a small card inside your phone that establishes a network connection. The SIM card is provided by your operator or service provider. In most cases, they are the best source of assistance with SIM card problems. Your phone may display a SIM card error message if:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. It may also be that your phone is configured so that it cannot be used with a SIM card from a different operator or service provider. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced. Or alternately, bring your phone to the nearest Nokia Care point for inspection
on Sep 12, 2010 • Cell Phones
tip
Puk code iphone
Hello and welcome to fixya.
You need to understand that puk code has noting to do with your phone, it is a personal unblocking key for the sim card.
This code is a random number generated by the service provider, each sim card has its own number / code.
No one can calculate or get this code for you, you only can contact the service provider to get the puk code. OR then buy a prepaid sim card or get another sim card, but you can't get the puk code if the service provider won't supply it to you. No one else can get it for you.
if you take the sim card out from the phone, the phone will work with another sim card.
The puk comes up when the pin code has been entered wrong 3 times. To get the puk code for your sim card, you have to call the service provider of that sim card. They are the only ones who can provide you with the rightpuk code for that sim card.
The puk code may also have came with the documentation of the sim card, if its a prepaid card the puk code comes on the documents or on the box of the product.
if your unable to obtain the puk code, get a new sim card.
also entering the puk code wrong too many times will eventually ruin the sim card forcing you to buy or contact your service provider for a new sim card.
There are no puk code calculators or anything that we can do about it, you can buy premium assistance and you will get this same response. There is no other solution.
You have to contact the phone service provider of that sim card or replace the sim card.
Thank you for understanding.
Ekse
1helpful
When you put a T-moble sim card in a i465 NEXTEL phone what is the special code
Sim cards are manufactererd accordign to phone types. However physically compartible sim cards usually are least functional with another device not intended to communicate. The sim card provides the link of communication also once established should not be tempered with else distorts the communications linkage. The code is the protection key that identifies the sim card to the phone that you own. First, tempering with a sim card during a functioning phones capability distracts from the service communcation provider. As a security medium, so after the sim card has been dislodged, the signal connection is by passed requirng a reset from the provider technitian. Contact the phone provider to revive missing sim card codes, or purchase another sim card to set a new code provided at the sells. Goodluck
2answers
I have bought this phone together with a sim card, the problem is I can't find my number to! Please help. Where do I find my number?
The cell phone's number is provided by the cell phone service provider together with the SIM card.
If the existing SIM card is a prepaid SIM card you will need to purchase a new pre-paid SIM card from a cell phone service provider and a cell phone number will be allocated to this SIM card.
OR
Purchase a cell phone plan with a cell phone service provider and you will get a new SIM card with an allocated cell phone number.
tip
SIM card Rejected ? orvSIM Card unaccepted?
The SIM card is the small card inside your phone that establishes the network connection. In almost all cases, your operator or service provider is the best source of assistance with SIM card problems.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. Please contact your current operator or service provider for assistance.
on Mar 14, 2010 • Cell Phones
1helpful
2answers
3answers
Need puk code
puk code, personal unlocking key. It is sim card related / specific, if you take the sim card out from the phone, the phone will work with another sim card.
The puk comes up when the pin code has been entered wrong 3 times. To get the puk code for your sim card, you have to call the service provider of that sim card. They are the only ones who can provide you with the right puk code for that sim card.
There are no puk code calculators or anything that we can do about it, you can buy premium assistance and you will get this same response. Theres no other solution.
Can't help you even if you paid.
1helpful
2answers
I have a LG dare and forgot my password to unlock my phone
The first step is to find out if the password is on your sim card. If you already know that it is on your sim card skip this step. Turn off your phone and open it up. You should see your battery. On most phones your sim card is located under the battery. When you find your sim card remember exactly how it goes into it's slot and take it out. Put the battery back into the phone and turn it back on. It will tell you that your sim card is missing and on most phones ask you if you want to start without a sim card. Press yes and see if it asks you for your password. If it does not, then the password is on yor sim card. Put the sim card back into your phone and call your service provider. Tell them that you forget the password to turn on your phone. They should be able to tell you what yor password is after they ask you a few questions. If the password was not on your sim card, then call your cell phone provider and ask them how to reset your password. Service provider: Verizon is a service provider. cell phone provider: LG is a cell phone provider.
Sim card rejected
Try inserting the sim card in another phone. If it still doesn't work, the problem could really be with the sim card. Go to your service provider, and request for your sim card number transfered to another sim card. That is if you wanna keep the same number. You could request for another sim card if you'd like. Call your service provider.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
