Televison & Video Logo
Gerry Posted on Sep 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung PS50A456P2DXXU NOT POWERNG UP - Televison & Video
  • Gerry Sep 30, 2013
    Checked fuse :OK
Russ Hill
Level 3:
  • Televison & ... Master 4,057 Answers
  • Posted on Sep 30, 2013
 Russ Hill
Level 3:
Answers
4057
Questions
10
Helped
1177727
Points
12696
Is the stanby light on?
  • 11 more comments
    Hi Russ Many thanks for responding - No the standby light is off - My son tells me he replaced plug fuse yesterday & TV worked fine. Would not power on this morning - Thanks - Gerry
  •  Russ Hill
    Russ Hill Sep 30, 2013
    then i would say it has blown the 5 volts side of the main power board. could be a simple as the internal fuse or the main power board has failed. they are easy to change just the board. i've just looked on line at prices and they are not to bad. but would check the internal fuse first.. mains plug fuse is 5am. internal is 3amp
  •  Russ Hill
    amp*
    Hi Russ - Many thanks I'll get the TV down & do as you suggest. Can you suggest a PSU source ?
  •  Russ Hill
    https://www.facebook.com/FlatTVParts?fre... give them the part number see how much with a trade in of the old board for a working one I have used these before. they are very nice. or the is the bay just put in the board part number and a load of board will pop up don't get from out of your countrie cost more on delivery.
    Thanks Again Russ - You've certainly helped - Much Appreciated
  •  Russ Hill
    I have also found a repair kit for PS50A456 BN44-00205A DYP-50W3 board on ebay depending on your soldering skills and the board number from 15-25pounds. if that may be an option. if you need help you can contacted me here. with the full board number.
    Hi Russ - Well my soldering skills are pretty good however I think I
    .... Will purchase a "working" board. I appreciate your replies and advice - hopefully "she" will be soon up and running:)
  •  Russ Hill
    that is ok hope it all goes well. if you get a cheap board without using a trade in you can fix it and keep it as a spare.. I have spare boards for mine
    Have a friend coming round later to help me lift it down. I'll be able to stick a meter on it & see what's "happening". Hopefully it will be a simple swap out - Gerry
  • Gerry Oct 01, 2013
    Hi Russ - Upate :) Fuse on main board blown - Replaced - Powered Up - Everything working fine! Thanks for all your support
  •  Russ Hill
    Russ Hill Oct 02, 2013
    you are welcome have a good time watching tv again. :)
2answers
Not powerng up.
Make sure that plug is in working order by plugging something else into it. If you need to get to the power unit inside the printer to test it, here's a video on how to get to power supply:
1helpful
2answers
Forgot my password for samsung e 390
Hello Dear,
Type the code * 2767 * 3855 # and the phonewill reset to the factory settings. Other interestingcodes for Samsung phones: * # 0228 # BatteryInformation
* # 0673 # Test MP3
* # 0782 # Date and Time
* # 0842 # VibrationTest
* # 1111 # SoftwareVersion FTA
* # 1234 # Softwareversion (short)
* # 1235789 # StateControl of Integrity
Hardware Version * #2222 # FTA
* # 232337 # BluetoothBroadcast Address View
* # 32489 # State ofCiphering
* # 742695 # Softwareversion, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to * # 8999* 8376263 #)
* # 8999 * 8376263 #Software version, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to 742 695* # #) * # 1546792 * #Admin settings (WARNING: not to experiment!)
(* # * 73561 # OperatorCode, where applicable)
(* # 2456987 * # MasterKey) # * # 123580 TestMode main menu (not to experiment!, Equivalent to * # 9998 * 324 #)
* # 9998 * 324 # TestMode main menu (not to experiment!, Equivalent to * # 123580 #)
* # 0002 * 28346 # ItemMenu Handset Volume (sub-menu of the Test Mode Menu)
* # 0011 # NetworkConnection Status
(Same as in Test Mode,which not only returns to the main menu of the Test Mode)
* # 7412359 # Test MenuRadiofrequency
* # 9999 * 0 # NetworkMonitor
(Same as in Test Mode,which not only returns to the main menu of the Test Mode) * # 7465625 # setthe Phone List of Blocks # 7465625 * 27 *code # Remove the "PC Lock"
# 7465625 * 638 * Code# Remove the "Network Lock"
# 7465625 * 685 * Code# Remove the "Multi Lock"
# 7465625 * 746 * Code# Remove the "SIM Lock"
# 7465625 * 77 * code #Removes the "SP Lock"
# 7465625 * 782 * Code# Remove the "Subset Lock"
# 7465625 * 228 #Disable "Activa Lock"
# 7465625 * 2827 #Disable "Auto CP Lock"
# 7465625 * 28638 #Disable "Auto Network Lock"
# 7465625 * 28685 #Disable "Auto Multi Lock"
# 7465625 * 28746 #Disable "Auto SIM Lock"
# 7465625 * 2877 #Disable "Auto SP Lock"
# 7465625 * 28782 #Disable "Auto Subset Lock" Malicious code:
* 2767 * 3855 #Reset Full Phone (back as "just bought") * 7465625 * 27 *code # Set the "PC Lock"
* 7465625 * 638 * Code# Set the "Network Lock"
* 7465625 * 685 * Code# Set the "Multi Lock"
* 7465625 * 746 * Code# Set the "SIM Lock"
* 7465625 * 77 * code #Set the "SP Lock"
* 7465625 * 782 * Code# Set the "Subset Lock"
* 7465625 * 228 #Enable "Activa Lock" to restart the phone
* 7465625 * 2827 #Activate "Auto CP Lock" to restart the phone
* 7465625 * 28638 #Turn on "Auto Network Lock" to restart the phone
* 7465625 * 28685 #Turn on "Auto Multi Lock" to restart the phone
* 7465625 * 28746 #Turn on "Auto SIM Lock" to restart the phone
* 7465625 * 2877 #Activate "Auto SP Lock" to restart the phone
* 7465625 * 28782 #Turn on "Auto Subset Lock" to restart the phone These codes areworth a bit more for all Samsung phones, in particular: Samsung E390,Samsung Ultra Video F500, Samsung F510, Samsung F520, Samsung F700, Samsung SGHi520, Samsung i600, Samsung i620, Samsung L760, Samsung P910, Samsung P920,Samsung P940, Samsung SCHB100, Samsung SGH F600, Samsung SGH i550, Samsung SGHJ750, Samsung SGH I600, SGH i607 Samsung Blackjack, Samsung SGH P930, SamsungSGH Z630, Samsung Ultra Edition 12.1 (U700), Samsung Z100, Samsung Z105u,Samsung Z107V, Samsung Z110, Samsung Z130, Samsung Z140, Samsung Z140V, SamsungZ150, Samsung Z170, Samsung Z220, Samsung Z230, Samsung Z300, Samsung Z310, SamsungZ320, Samsung Z330, Samsung Z350, Samsung Z360, Samsung Z370, Samsung Z400,Samsung Z500, Samsung Z510, Samsung Z520, Samsung Z540, Samsung Z550 , SamsungZ560, Samsung Z600, Samsung Z610, Samsung Z620, Samsung Z650i, Samsung Z700,Samsung Z710, Samsung Z720, Samsung ZV10, Samsung ZV30, Samsung ZV40, SamsungZV50, Samsung ZV60, Samsung ZX10, Samsung ZX20. WARNING: Someof these codes may cause blockage or malfunction of the cell, therefore, it isunderstood that you use them at your own risk.
2answers
On-off switch faulty. How to I access it to replace it? Acer 19116W A, version 19116W Asd
I doubt it very much that it is bad switch. Can you feel it click?
Here are the pcitures: http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
2helpful
How to connect my samsung led tv to samsung galaxy tab through all share
how to connect my samsung led tv to samsung galaxy tab through all share
11helpful
4answers
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
