SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
SOURCE: need to change language on Nikon D60
Within the menu items that can be viewed on the back of the camera, there is a language option that you can set. You may have to scroll through all of these to get the correct setting. Nikon tends to change the menu layout from camera to camera, so it may not be the same in your D60 as it is in a D300 or other model.
SOURCE: How can i repair my D60 Nikon lens? It wont zoom
Sounds like its damaged, if the zooming is stuck. It might have fallen causing internal parts to damage.
I strongly recommend contacting Nikon service for this kind of repairs, because its far too easy to trouble the glass if you open it. I mean even if you manage to fix the issue many things can go wrong inside and the lens wont be come out clean. Better to leave it to professionals here.
Ruchir
SOURCE: My Nikon D60 "Error. press shutter release button
Hi
The error is with the shutter release button and the unit has to be taken apart....Get it repaired by Nikon it is a common problem with these units.
Thanks for using FixYa
Have a Nice Day
