Question about Element Electronics FLX-2210 22 in. LCD HDTV
Factory restart - Element Electronics FLX-2210 22 in. LCD HDTV
Factory reset Dell Inspiron 1500 windows 8
Restart your computer by clicking Start > arrow next to the Lock button > Restart.
As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
Note: You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Press the Down arrow to select the Repair Your Computer option on the Advanced Boot Options menu, and then press Enter. Select your language settings and then click Next.
Log in as an administrative user, and click OK. Then click the Dell Factory Image Restore option.
In the Dell Factory Image Restore window, click on Next. Check the box that reads Yes, reformat the hard drive and restore system software to factory conditions, followed by Next.
The computer will now restore to its default factory settings. Once the restore operation is completed, click on Finish to restart your computer.
Apr 16, 2017 | Dell Computers & Internet
How can I restore a Dell laptop to the factory default settings?
Here are the main steps to restore your Dell laptop to its factory settings. Depending on the model you own, the procedure may vary slightly.
Before beginning, please note that by restoring your computer to its default factory configuration, all data on the C drive will be deleted. We highly recommend backing up any personal files before moving forward with the reset.
Hard Reset Dell Laptop Restart your computer by clicking Start > arrow next to the Lock button > Restart.
Feb 27, 2017 | Dell Computers & Internet
I had to factory reset my tablet and after it factory reset it shut off and when it turned on again it said 'the computer restarted unexpectedly or encountered an unexpected error.
Help laptop wont start after resetting factory settings - Acer ...
www.tomsguide.com/.../77186-35-help-laptop-wont-start-resetting-facto...
Mar 25, 2012 - 5 posts - ‎2 authors
i restored my laptop back to factory settings as it kept crashing, now when i ... TVs · Cameras · Smartphones · Tablets · Software · 3D Printing; More ... or encountered an unexpected error, windows installation cannot ... then restart the installation... i do this and its just repeating itself, i have no recovery discs.
"The Computer Restarted unexpectedly or encountered an ...
heresjaken.com/the-computer-restarted-unexpectedly-or-encountered-an...
Feb 1, 2013 - Now your computer will restart and continue on the Windows setup process ... THOUGHT MY 1000 DOLLARS COMPUTER HAD CHRASHED AND .....setup experienced an unexpected error" To install windows, restart the installation. .....JUST fyi - I had a similair problem on a Surface Pro 3 tablet and this ...
encountered unexpected error when going to factory reset ...
h30434.www3.hp.com > Laptop & Notebook > OS/Recovery
Jan 13, 2016 | Computers & Internet
GT s5222 gets restart wn i click alaram menu what to dO?
Hi dadhan, do a factory reset 2 - 3 times in a row and turn the phone off for at least 10 sec then on again, then do a factory reset. Hope it works for ya. Greg.
Oct 28, 2014 | Samsung Star GT-S5233 Cell Phone
How to reset to factory default
Restore the factory-set defaults
CAUTION:Restoring the factory-set defaults returns all of the product and network settings to the
factory defaults. The procedure then automatically restarts the product.
1.
On the product control panel, press (X451 Series) or touch (X551 Series) the Setup
button.
2.Scroll to and press or touch the Tools menu button.
3.Scroll to and press or touch the Restore Factory Defaults button, and then touch the OK button.
The product automatically restarts
Jul 22, 2014 | HP Officejet Pro X451dn Printer
Factory restore
Dell Dimension computers have a built-in PC restore system that allows you to quickly restore the PC to its original factory settings.
The PC restore is located in a hidden partition of the PC's hard drive and contains a copy of the computer's original factory installed software.
There are two different ways to restore the Dimension's settings depending on which operating system your computer is running.
Windows XP
Disconnect all peripheral equipment that is attached to your computer such as printer, scanner, external hard drive and memory sticks.
Restart the computer.
After the Dell screen appears on the monitor, hold down the "Ctrl" key and press the "F11" key.
If the Windows XP screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
Highlight "Restore" in the Dell PC Restore window by using the tab button.
Hit "Enter."
Highlight "Confirm" in the restore warning box by using the tab button.
Hit "Enter."
This will start the system restore process.
Do not attempt to turn off the computer during this process or vital system files may be damages and you will not be able to restart your computer.
Click "Finish" in the box that notifies you that the restoration has been successful.
Hit "Enter" to restart the computer.
The computer has been restored to the original factory settings.
Windows Vista
After the Dell screen appears on the monitor, press the "F8" key.
If the Windows Vista screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
Highlight "Repair Your Computer" by using the down arrow key in the Advanced Boot window.
Hit the "Enter" key.
Click "Next" after selecting a language. Log into the computer as an administrator.
"OK." Choose "Dell Factory Restore."
Click "Next."
Check "Yes" next to the reformat the hard drive and restore factory settings option.
Click "Next" to start the restoration process.
The computer will automatically restart itself to its original factory settings.
Aug 18, 2013 | Dell Dimension C521 PC Desktop
Myy hp laptop i need to return to factory settings
Press the "Start" button in Windows Vista. Select "All Programs" and "Recovery Manager."
Click "Advanced Options."
Select "System Recovery." Click the "Next" button.
Click the "Restart" button when prompted by the on-screen instructions once the recovery is done.
After restarting the computer the system is back to its factory state.
hope this helps
Sep 24, 2012 | Computers & Internet
How to set a dell back to factory
Restore the computer to the default factory configuration
Note:
When you restore the computer to the default factory configuration, all data on the C drive is deleted. Before performing this procedure, back up any personal files. If you do not back up these files, the data will be lost.
  • 1. Restart the computer
    • To do this, click Start, click the arrow next to the Lock button, and then click Restart.
  • 2. As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
    • Note: You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  • 3. Press the Down arrow to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
  • 4. Specify the language settings that you want, and then click Next.
  • 5. Log in as a user who has administrative privileges and click OK.
  • 6. Click Dell Factory Image Restore.
  • 7. In the Dell Factory Image Restore window, click Next.
  • 8. Check the box saying Yes, reformat the hard drive and restore system software to factory conditions.
  • 9. Click Next. The computer is restored to the default factory configuration.
  • 10. When the restore operation is completed, click Finish to restart the computer.
Jun 29, 2012 | Dell Inspiron 1750 Laptop
Cant open windows, have got following error code; Oxc0150002 i want to restore factory settings how can i do this?
Hi, Restore the Computer to the Default Factory Configuration
Notice:
When you restore the computer to the default factory configuration, all data on the C drive is deleted. Before performing this procedure, back up personal files. If you do not back up personal files, the data is lost.
  • 1. Restart the computer. To do this, click Start, click the arrow next to the Lock button, and then click Restart.
Note:
Good Luck (please don't post in all CAPITAL LETTERS next time)
  • 3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
  • 5. Log in as a user who has administrative credentials, and then click OK.
  • 8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
Nov 14, 2010 | Dell Inspiron Mini 10 Notebook
Element Electronics FLX-2210 22 in. LCD HDTV Logo
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
