Probably near the spot where your electrical hook up cable comes out of your RV. Sometimes there is another sub-panel inside the RV ....Usually inside one of the smaller cabinet doors. Mine is under my oven/cooktop combo. Check the GFI switch too. Usually the plug receptacle in your bathroom. Push the test button....if it clicks out the other button....that means it wasn't tripped, if it doesn't click out the other button....you found the problem....press the other button to reset the GFI. Good luck and always work safely.
please test the battery by new ones, clean the contacts batteries and replace . test the reed switch see the diagram attached. However you must download from www. fitness.manualsonline.com
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
