Many times when I am talking on the phone, the phone will make a high pitched, quiet buzzing, disconnect the call, seemingly reset to insert sim. I then take the battery and sim out, reinsert, and power on. And it is a continuous cycle. Sometimes, this will happen at some time and I will pick the phone up, and see the error message insert sim on the screen. It only happened a couple times at first, but now it is every other time I use the phone, if not every time.
DSLReports
Oct 3, 2009 - 30 posts - 7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
The "Enter PUK code" message means that the SIM card is blocked. ... Simply insertthe SIM card into the back of your phone or make sure that the SIM card ... on you may receive this message because your phone has not yet been Activated.
Straight Talk offers a variety of phone models to choose from. .... do support a SIM Card. However, if your iPhone is a 4 or 4S, DO NOT insert a SIM Card into it.
Nov 8, 2015 - 25 posts - 12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
I'm using HTC TyTN II with Windows Mobile 6.1 as OS. My problem is my phone keep loosing network signal and occasionally when it get the signal, I can't make a phone call. The signal is there, but when I make a phone call, it will disconnected at once.
Do you have the Play n Charge Kit connected? It seems if you use that with the X1 at the same time, some kind of hum noise is transmitted through the USB bus power to the X1 headset, and you hear a buzz or high-pitched hum. The solution is to use the X1 without the Play n Charge Kit, and charge the controller when you're playing the sound through your TV instead of the headset.
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
Often, after a power surge that exceeds the parameters of surge suppression devices on the circuit board, the unit will do this. You will more than likely have a failed control board now and will need to replace it.
It happens with some television speakers..There seems to be excessive hiss and buzz at high volumes if its happening even at low volume then check your tv's signal reception(ask ur connection service provider for help)If this doesnt fix the problem since the product is in its warranty period just drop into a service center and they will fix it for you
