IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer! You can find the radio code at: http://www.radio-code.co.uk/
The sequence of programming for 2004 Audi A4 radio is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
The sequence of programming for 1997 Audi A4 radio is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
The sequence of programming for Audi radio is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
remove the back panel look on the side of the heating element look for a small red button on the thermal fuse push it in.
Also look on the left side by the belt and motor you should see a black piece of plastic with small springs on it push it to the right to reset it if this has tripped,this is a saftey kill switch that gets activated by the drum belt if there if a sudden problem with the belt tension
I had the exact same problem on my 1998 Audi A4 Quattro Sedan I just purchased. I read a couple of other posts that said to try looking for the radio code in the spare tire compartment in the trunk. Sure enough on the right hand side of the compartment was a information label and on it someone had written the code 1174 in pen. I then left the key in the ignition and the radio on for an hour. Then I pushed the DX and FM1/2 button and the same time until the "1000" number appeared on the display. Then I pushed in the code 1174 using the 1 - 4 tuner buttons. For example the number 1 key I pushed until the number 1 appeared. Then pushed button number 2 until the number 1 appeared, pushed button 3 until the number 7 appeared and button 4 until number 4 appeared. After I had the code 1174 on the display, you again push the DX and FM1/2 button at the same time and the radio unlocked and worked perfectly. I hope that this helps. I have the Delta (Bose) AM/FM Cassette radio in my car. Good Luck!!
