I HAVE A 2001 DODGE RAM 1500 CHANGED FRONT BRAKE PAD AND REPLACED DRIVER SIDE CALIPER WHEN I DRIVE I HERE RUBBING NOISE COMING FROM DRIVER SIDE SOUNDS LIKE PADS ARE RUBBING WHEN I APPLY BRAKES IT STOP'S
check rotor it needed to be cleaned and plate cleaned put back together no more rubbingcheck rotor it needed to be cleaned and plate cleaned put back together
no more rubbing
You can't post conmments that contain an email address.
You could easily have a front wheel bearing going bad. They tend to get louder when turning. The squeal can be from the bearing itself, or possible from the brake rotor rubbing on the brake stone guard behind the rotor when turning. That rubbing won't occur unless there is excessive play in the wheel bearing or if the guard is bent.
? 14:28
https://www.youtube.com/watch?v=WvRyg95cUIQ
Nov 1, 2010 - Uploaded by spelunkerd
If you have gear oil leaking from a front axle tube then this is a ...a circular hole saw (he says about 2-2 1/4"), grinding the teeth down, ... Hey my 2001 ram has a big puddle coming from it'sdriver side wheel could this be it?.
Have you not looked over the brakes & even taken things apart, looking for & eliminating brakes as an issue? Checked drive axles,joints,etc. Tires won't make a noise & brakes are not near the wheel, to touch anything New wheel hubs are ruined by mechanics obsessed with those air driven impact guns,you need to use a torque wrench on the axle nut of a new bearing
the noise is probably the ware sensors on the brake pads making noise the noise lets you know that the brakes are getting thin are are ready to be replaced.if you let this go to long you can damage the brake rotors, make sure you check to make sure the caliper is not sticking on the left side being this side is making more noise ,a stuck caliper can cause premature brake pads ware .
The hard part is pressing the caliper piston abck into the caliper so you can get the new, thicker pads over the rotor. A large C Clamp works best.
SECTION 206-03: Front Disc Brake
2001 Villager Workshop Manual
REMOVAL AND INSTALLATION
Pads —Front Disc Brake
Removal
Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
Remove the front disc brake caliper bolts. torx bit. T20?
Support the front disc brake caliper from the front strut and spring assembly using mechanics wire.
Remove the front disc brake pads.
Remove the outboard front disc brake pad.
Remove the inboard front disc brake pad.
Installation
CAUTION: Make sure the master cylinder reservoir does not overfill and spill brake fluid while retracting the front disc brake caliper piston. NOTE: It is necessary to fully retract the front disc brake caliper piston in the bore before installing the front disc brake pads. Install the front disc brake pads.
Install the inboard front disc brake pad.
Install the outboard front disc brake pad.
Caution. The outer pads are left and right. put left on driver side.
Position the front disc brake caliper on the front-wheel knuckle and install the brake caliper pin bolts.
WARNING: It is necessary to depress the brake pedal several times to position the front disc brake caliper piston before driving the vehicle.
the ansew i found is replacing the seal around the joint and from both end removing it and cleaning it out i had rocks in mine from going threw water and mud ita a all day deal but a twenty doller fix axle shaft oil seal is all i had to replace
no more rubbing
