I would suspect you have a power problem. Voltage too low or high can damage electronics very quickly. Voltage spikes also can fry TV's. Your power company can help. Monster makes a complete power solution with sophisticated filters and a power supply regulator that will keep power within specs but you will spend close to $ 1000 for this solution. I don't think Humidity is the culprit but corrosion due to salt is another matter. If salt is the culprit then you are out of luck unless you want to install the kind of air filtration system used for a shelter from Atomic Attack.
Using the KISS principal I would check the power first.
SOURCE: Sony Bravia TV went Blank
COULD BE LVDS CABLE LOSE OR NOT MAKING A GOOD CONTACT , IF IS NOT THAT UNFORTUNATELY IT WILL BE NECESSARILY TO REPLACE T CON BOARD
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
SOURCE: Picture problem
raystratton
I was wondering if you were able to solve this issue. i am having the same exact issue with my tv. and i did not get an extended warranty thinking that nothing would go wrong with a sony tv. i learny my lesson the hard way. Can you please tell me what the tech told you or what you did to fix this problem. All your help will be greatly appreciated. Thanks once again!!!
SOURCE: Sony Bravia KDL-52XBR9
There is a error in TV.Count how many times blinking the red light.
Testimonial: "I also bought the Sony KDL-52xbr9 mine did the same thing with six blinks. I sent it back to to store. "
