Our original remote and user manualare gone-along with the aspect button on the original remote. No universal remotes that work for the TV have the aspect button-we can't get the picture off of panorama-there is no menu option to change the picture aspect. Is there a way to reset the TV
Without its remote control, you can't do a system reset to this set.
Try a Hard Reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If a hard reset do not help, you should buy its original remote control from its authorized service center.
SOURCE: Element LCD 32" TV- expand the screen
You will need the original remote to operate the different screen modes.
My TV has the same problem, without that silly special button on the remote, I'm not able to change the screen size without it.
I google "FLX3210 remote", 3 web sites are selling it for less than $45.
I hope I answered your question correctly. Please rate me
SOURCE: I lost the remote and cant find a universal that
you can go to menu options, than find programming options.
Look for an option called "autoprogram" and select it. It will search and set all available channels.
There is universal remotes for this tv that you can find by googling "elements electronics remotes":
SOURCE: Element tv has a blackout square over most of the
Turn off the text mode in the closed captioning menu.c/c button
Testimonial: "Thank-you, that was it!!"
SOURCE: tv not responding to remote or buttons on tv
Try this website to get an original remote.1-800-Remotes Factory original.Still same prob. got a new remote,than the tv pannel control board it dead.
