You may need a phono pre-amp to connect it to your unit. Newer receivers do not have a phono input for the record player and require a phono pre-amp to amplify the sound before going into the unit.
http://www.guitarcenter.com/Behringer-Microphono-PP400-Phono-Preamp-104009048-i1125385.gc
SOURCE: fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
SOURCE: turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
SOURCE: Connect a phonograph turntable to a receiver w/o phono connection
you will need a little box called a pre-amp. This hooks up between the turntable and newer receivers without a phono input. A basic explaination & drawing of this type of setup can be found here
http://www.turntableneedles.com/Pre-Amps_c_4.html
SOURCE: old turntable works but is too quiet to hear
It sound like you may have to hook your turntable up to a phono input. Turntables have low level outputs. The phono input is designed to amplify this low level more than the cd/dvd inputs do. If you do not have a phono input, you can buy an external "phono preamp" online. Hope this helps.
SOURCE: ION TTUSB05XL - Poor sound quality
the turntable has a built-in phono preamp so you don't want to run it through phono inputs in your receiver but just regular auxiliary inputs instead
