Question about Electronics - Others
Can't Reformat Kingston DataTraveler 2.0 USB memory stick
I have a Kingston USB DataTraveler memory stick with 8 GB capacity. I was using nUbuntu Linux which is a Live CD and selected an option called "Install to USB" so that I can boot the Linux OS from my USB stick. I did that but halfway through I pulled the USB stick out. Now when I look at it through Windows XP, the name has changed from "Kingston DataTraveler" to "Live". Windows allows me to format it to eith FAT or Fat32, but in the capacity box, it only allows me to format it to 806 MB, rather than the full 7.5 GB/8 GB.
The 806 MB is, I assume, the size allocated by the Linux distro for the bootable Linux OS.I can't no longer format it to the original size. What do I do?
  • generic_emai May 30, 2009
    Thanks for the info.
    I solved it with the HP USB Disk Storage Format Tool. Quick and simple without any command line needed :-)
    http://www.pcworld.com/downloads/file/fi...
  • Anonymous Mar 22, 2014
    My USB stick:DataTraveler 100G3 is not recognised and not optimised.I tried fomatering it afew times with FAT
  • 272 Answers
Use any linux bootable distro, like puppy (100 MB ) Slax ( 200 MB) or ubuntu to make a live boot, or use any pc which has linux installed can format your USB to its full capacity.
Posted on Apr 20, 2009
    Problem Solver:
  • 7 Answers
It probably has two partitions on it now, the 800MB and then the rest.
Use a bootable distro like those above, open a terminal and run: fdisk -l to see which disk is your USB drive, say /dev/sde
then run sudo fdisk /dev/sde
Press d
tell it partition 2
Press d again
it should delete partition 1
Press n
Tell it that you want a primary partition
Accept the defaults for the rest of the questions
Press t to change the partition type
Type c (Fat 32, LBA)
Press w (write the partition)
Then you'll need to format the drive with:
mkfs.vfat /dev/sde1
That should do it.
Posted on May 30, 2009
SOURCE:
Datatraveler g3 driver
go to start , RIGHT CLICK on My computer the select manage.
In the window that will open choose manage disks and reformat your usb stick (if it's not shown there connect it into another port and repeat )
May 13, 2013 | Kingston 4GB DataTraveler I Generation 3...
My usb is empty files are gone how can I recover data
yes, you can recover deleted files from usb drive, take a look at this step by step usb drive recovery guide. The guide helped me before, quite easy to follow and works well for me. hope that it help you get back lost data.
Apr 20, 2013 | Kingston Technology Flash Kingston...
Kingston Datatraveler Windows 7.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
eventhough the device is not present, causing the said error.
Aug 15, 2012 | Kingston Computers & Internet
How to convert 2gb sd card into 4gb
How to convert 1 or 2GB memory stick into 4GB?
Just follow the simple instructions:
Step1: Insert your memory stick in USB port
Step 2: Open the Drive increaser software folder (download the software)
Step 3: Rename the Pendrive or memorystickimage_thumb%25255b35%25255d.png?imgmax=800
image_thumb%25255b32%25255d.png?imgmax=800
Step 4: Open Drive Increaser 2 icon from the Downloaded folder.
image_thumb%25255b6%25255d.png?imgmax=800
Step 5: The opened file is asks USB drive Name. (Before enter the name first Rename the Memory stick or Pen drive). Just enter the renamed pen drive name. Ex: 2341
image_thumb%25255b16%25255d.png?imgmax=800
Step 6: After that, it will ask USB pendrive letter (Ex: H or I or J). Repeat this two times
image_thumb%25255b43%25255d.png?imgmax=800
Step 7: After Drive letter entry some process will be done with Red color like this image
image_thumb%25255b49%25255d.png?imgmax=800
Step 8: Finally it shows Done Please enter any key to done.
image_thumb%25255b56%25255d.png?imgmax=800
Now your Pen drive is 4GB
image_thumb%25255b63%25255d.png?imgmax=800
Jan 12, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to rename kingston pendrive 8 gb datatraveler 101
I tried renaming it by right clicking but its not working.its 8 GB kingstone pendrive.can you help?
Oct 16, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I made partition in my Kingston 4 GB USB and one of the partition is not opening. I want to delete partitions to get my 4 GB capacity back.
Probably best to copy all files off and reformat it.
It would have made more sense to use folders and not partitions.
You may not be able delete the partition if you cant open it.
Does it show up in disk manager?
Jul 22, 2010 | Kingston 4GB Secure Digital High Capacity...
My 2 GB Kingston memory card is locked. how to open it?
You'll need to reformat the card in order to reset the flash memory.
This is fairly simple to do. Simply insert the card into your card slot and go into My Computer (or just Computer in your start menu, if you're using Windows Vista or 7).
Next, right click on the icon that represents your card (this will be easily recognizable by looking at the capacity of the drive, it should be around 1.6-1.8 GB) and select "Format...". Format your drive using the recommended settings (usually FAT32, Quick Format) and you should be able to access it.
Mar 22, 2010 | Kingston 2GB Secure Digital Memory Card
Kingstone datatraveler 2gb
i do have a 2 gb pendrive .  now it is showng a capacity of 17 MB only. what is the problem
/  how to solve it.
Aug 11, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Electronics - Others Logo
1,360 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
