SOURCE: I have a honda 2600 pressure washer. After
This is a symptom caused by a sticking Unloader valve. The Unloader valve is inside the pump outlet body under the large black knob.
Example picture : http://www.msservice.net/product_spotlight.html
Before doing any dis-assembly try this procedure first. This may sound weird but it often works. We do this with a short piece of garden hose,,,,, Add 3 to 4 ounces of engine oil into the water inlet by pouring the oil into and old short / cut off garden hose with the end elevated but connected to the pump inlet.
Slowly pull the engine starter cord so as to pump the added oil into the pump and let it sit over night. Just keep pulling the starter cord "IGNITION OFF" until you note oil exiting the high the high pressure hose connection.
Then connect everything like you normally would the next day.
MAKE sure to purge the water supply hose of air at the pump connection before starting the engine.
Start the engine. NOTING that your going to shoot out the oil you put in the day before..... Pull the wand trigger every 3 to 4 seconds so you cause the Unloader / thermal relief valve to stroke within the pump body. Don't give up... you have to do this for an extended period of time so that you have HIGH pressure each time you pull the wand trigger.
With the engine still running.... let it run trigger off for about 1 minute at mid engine speed. Pull the trigger again and see if you have high pressure. Do another long pause... then use as you normally would.
IF the above lubrication process does not work....
The Unloader / thermal relief valve needs to be dis-assembled so that the springs and seals can be lubricated with Lubriplate #105 white grease. Make sure to also lubricate the casing of the pump body before putting everything back into the pump body.
Here is the white grease tube your looking for at any automotive parts supply.
http://www.lubriplate.com/products/greases/no-105-motor-assembly-grease.html
This should get you going again. Just note that Unloader valves will notoriously stick after end of season storage upon the next use. It is important after an extended non-use period that the wand trigger is cycled every 3 - 4 seconds to exercise the Unloader valve springs and seals in the pump body. You only need to do this for about 45 seconds.
Thanks for choosing FixYa,
Kelly
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Thank you for contacting fixya.com.
FH
error code means low water inflow. In this error washer is not filling when the
fill valve opens.
To clear the error please follow the bellow instructions:-
Press the "Stop" button twice with your finger. This cancels the
cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the
water shut off valves clockwise to stop the water flow to the washer through
the supply hoses. Pull the washer away from the wall enough that you can access
the hose connections at the back of the washer.
Set
a bucket under the area of the hose connections. Unscrew the hose connections
from the back of the washer. If necessary, use a pair of slip joint pliers to
help start the connections turning until you can turn them by hand. Set the
ends of the hoses inside the bucket.Inspect the screens on the inlet ports on
the back of the washer where the hoses connect. Sediment and other debris can
block these screens, causing fill problems. Clean the screen with an old
toothbrush.
Thread
the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off
water supply to the washer which causes the FH error code. Once you connect the
hoses, turn the water supply valves counter-clockwise to supply water to the
washer. Move the bucket away from the washer and push the washer back into its
working position.Plug the power cord back into the outlet and start the wash
cycle again. If the FH error code comes up again, call a service repairman. If
the hoses have no kinks and the inlet screens are clean, there is a problem
with either the pressure switch or the flow meter.
Please get back to us if
you have further query else please accept the suggestion.
