GMC bolt. engine lift. fan and coolant pump. generator mounting Logo
Shall Turner Posted on Sep 28, 2013
I have a 2006 Chrysler 300 and it is running hot and the fans will not come on I just replaced the radiator what could be causing my car to over heat
Bob Baron
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Oct 01, 2013
Bob Baron
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
1151
Points
8
Check the thermostat, they will stick closed and cause overheating. or replace the switch for the fans.
How do I remove and replace the water pump on a 2006 Chrysler 300 hemi 5.7 l.
5.7L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect negative battery cable.
  3. Drain the cooling system.
  4. Disconnect negative battery cable.
  5. Remove the upper radiator hose.
  6. Disconnect cooling fan electrical connector.
  7. Remove cooling fan mounting bolts.
  8. Remove the radiator cooling fan assembly from vehicle.
  9. Remove the radiator fan assembly.
  10. Remove accessory drive belt.
  11. Remove thermostat.
    NOTE The water pump mounting bolts are different lengths. Note the location of the water pump mounting bolts.
0996b43f80200d65-mw3da2o1okphbx00ygfzxzdl-4-0.jpg To install:
  1. Install water pump and mounting bolts. Tighten mounting bolts to 20 ft. lbs. (28 Nm).
  2. Make sure double ended bolt is in the proper location. Tighten double ended bolt to 20 ft. lbs. (28 Nm).
  3. Position the radiator cooling fan assembly in vehicle.
  4. Install cooling fan mounting bolts. Tighten to 50 inch lbs. (6 Nm)
  5. Connect the cooling fan electrical connector.
  6. Install the upper radiator hose.
  7. Install thermostat.
  8. Install the accessory drive belt.
  9. Install the radiator fan assembly.
  10. Connect negative battery cable.
  11. Fill the cooling system.
  12. Pressure test cooling system.
Turn the a/c on and the car overheats
Might be cooling fan clutch or the electric fan could be broken, the engine-cooling fan moves air through the radiator when your car is stationary or traveling at a slow speed, this air removes the heat from the coolant created by the engine, using the radiator as a conductor. When the cooling fan no longer works it causes the coolant to overheat which causes the engine to overheat. Also check the radiator, when the AC is turned on, the heat released from the condenser located in front of the radiator reduces the radiator's ability to remove the heat and the engine starts to overheat.
I have replaced the the Thermostat on my Chrysler 300 with the 5.7 Hemi Engine. It still over heats. Is there more than one thermostat on thi engine?
You didn't state when it overheats, if it is while driving the fault can be : belt driving water pump slipping , lower radiator hose collapsing, most common is clogged radiator. Start the engine with the radiator cap off when it is COLD and observe the flow in side. If you see really fast flow of coolant you have the bottom portion of the radiator stopped up. The only way to know is to remove the radiator and have it flow tested.
A blown head gasket or cracked head will cause steam to come out of the exhaust, water in the oil (milky). If it is running hot while idling , check fan to see if it is turning as it should when it should. Older cars have fan clutches that go bad, newer ones have temp thermostats that go bad.
My radiator cooling fans are ticking and smells like its rubbing and burning. can i disconnect one fan
probley wouldint be a good ideal the coolness of your eng is the life of your car get it to hot its done fans might be cheaper than a moter
My coolant light come on and my tempeture gage shot to the red zone in my 2006 chrysler 300 can I reslove this matter or do I have to take it to the dealership
Simply replace your heat sensor located next to your thermostat housing on the top of your motor. Also its a good idea to check your coolant level sensor located within the plastic overflow bucket. Both can cause this un-reliable reading on the heat gauge. Be sure that the thermostat is not sticking shut or open as it to can cause this problem as well as the cooling fan not comming on when it should located by your radiator.
Both of my radiator fans went out... short or what?
check your power supply to rad fan relays
2helpful
2answers
I have a heating problem onn 2006 chrysler 300 touring. with no engine light? temp guage just shoots up while running then comes back dwon to normal? how do i fix this?
I presume the engine is actually overheating -(not just a temperature gauge sender issue - check for poor connection at sender).
If so, go through the checklist following:-
1) Check engine cooling fan/s are operating as required when engine temp rises above cut-in threshold - check fan control relay is ok,
2) Check for collapsing radiator hose on suction side of water-pump when motor revs raised above idle.
3) Check coolant reservoir pressure cap is serviceable,
4) Check coolant system is properly filled - carry out any bleed off procedure specified to clear any air locks- (ensure heater core coolant flow is turned on).
5) Check condition of radiator core:-
i) for blockage of air flow to (bugs/grass etc),
ii) for core internal blockage to coolant flow,
Replace the thermostat, if all above ok.
2helpful
Replaced cracked radiator in 2000 Chrysler LHS but car still overheating. What could be the problem?
fix the radiator first.because coolant temperature sensor need to be in antifreeze.when antifreeze get up to 190 degrees. the coolant sensor act as a thermostat.it resistance decrease then the pcm will command cooling fans to run.if antifreeze low the coolant temperature sensor not going to work. engine is going to over heat.
2answers
Top GMC Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a GMC Electrical Supply Expert? Answer questions, earn points and help others
