SOURCE: Gray Lines
What do you mean by "Its only when i go to record or view previous recording"? in what situation doesn't it show the gray lines? What about the viewfinder? do you get lines there aswell? If you don't see the gray lines when you transfer the video out of the camera, then you don't have a head problem, a screen problem maybe. Don't hurry to use cleaner tapes because they can hurt the head, the actual cleaning procedure is one that scrapes the head and leaves some damage. more info please
SOURCE: I can not record video but I can watch the tape that I shooted before
Canon writes at its website http://www.usa.canon.com/consumer/contro... Malfunction: It has been confirmed that the connecting parts of the internal wiring of the CCD used in affected products may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments. If this occurs, the signal is not output from the CCD normally in Shooting Mode, which may cause a distorted image or the absence of an image. This malfunction can be confirmed on the LCD monitor screen during shooting. The same malfunction also appears on the recorded image. Canon's Response: Effective immediately, and regardless of warranty status, Canon will repair, free of charge, the products listed above exhibiting the above-mentioned malfunction if Canon determines that the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair. U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to [email protected]
SOURCE: Sony Handycam issue - repair/replace?
Your camera has bad CCD Imager and needs to be replaced this part. Good news is Sony will repair your DCR-TRV19E free of cost. Please check Sony Website for details.
Regards,
SOURCE: LCD buttons not working
I haven't the solution, but this may help some users. The camera has a LCD calibration menu. If LCD doesn't work properly use the remote control to get in to it. Try to calibrate the screen. This may be some help however didn't work for me, because I got no response from LCD panel. To calibrate remove all data (disc and memory stick). Click play/edit button, then use the remote control to p-menu > setup > standard set > calibratio. good luck!
SOURCE: Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
