I have an Insignis TV and need to know how to program this remote to use it. I have no instructions. Help??
SOURCE: Jensen SC-570 Universal Remote Control
I have a suggestion , Stop posting complaints and until you find out how stop coming here and reading tese stupid ass comments that lead you no F**King where
Try the auto code scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
Turn on the component that you want to set up.
Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
Release the component key.
If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
Press "0" - "9" The green light will blink as codes are sent.
As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
If none of the codes turn your component off, return to step 2 and start over.
SOURCE: unable to recode my jensen surf series sc330 universal tv remote control
Hi awaiting,
You should be able to use a search engine with the keywords:
Jensen sc330 Codes
It appears to be a number of websites that have digital copies of the codes.
Sincerely
Agent Jon
Go Ahead. Use Us.
SOURCE: tv universal remote/jensen surf series sc330
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: instructions for programming jensen jr 300 remote
I'm not sure if your remote will operate the vizio TV. You can try a code search and see if that works because the vizio TV is not listed.
Here is the user's manual.
