Cell Phones Logo
A
Anonymous Posted on Sep 27, 2013
Can not pair my phone to Cadillac CUE system, need instructions on what to do!
Chrysler 2013 300c uconnect bluetooth is not working showing " Bluetooth pairing not successful". I can't even add new device.
There are a few things you can try to troubleshoot this issue with your 2013 Chrysler 300c's Uconnect Bluetooth system:
  1. Make sure that your phone's Bluetooth is turned on and that it is in pairing mode.
  2. Check the Uconnect system's settings to ensure that Bluetooth is turned on and that it is set to discoverable mode.
  3. Try restarting both the Uconnect system and your phone to see if that resolves the issue.
  4. Check the vehicle's manual to see if there are any specific instructions for pairing a device with the Uconnect system.
  5. If the above steps don't work, try clearing the Uconnect system's memory of previously paired devices, and then try pairing your phone again.
  6. Check if the software of the Uconnect system is up-to-date, if not update the software.
  7. Try deleting all previously paired devices on the Uconnect system, and then try pairing your phone.
If none of these steps resolve the issue, it may be a problem with the Uconnect system itself and you may need to take your vehicle to a Chrysler dealership for further assistance.
1helpful
Need a CD player to be paired with Cadillac Infotainment system (In Car Audio System) Can I output to a Bluetooth Transmitter to pair with the car system using a portable CD player
If you have a Bluetooth receiver with a 3.5mm adapter and a 3.5mm aux input in your car - you can Bluetooh your device and use the Aux input to accept your audio.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
1helpful
Hi , i have panasonic TDA100 ipbx system i recently buy kx-tda170 hybrid extension card and install to pbx how can create extension from 25aid cable
The 170 card is an 8-port DHLC and it's pinned exactly like the old 123211 and the TD series systems where the first 2 pairs are the voice and data for a Panasonic Analog phone or a single line set on the first pair, and the 3rd pair is unused in the TDA. There are 8 3-pair sets in the cable and the 25th pair is nothing. Here's a link to an installation manual http://public.carl.airpost.net/Pana/TDA/100_TDA_IM_07-04.pdf The instructions start on page 139.
Carl
2helpful
2answers
Need pairing instructions
To pair your Plantronics Explorer 230, click on the following and should only take a few minutes with detailed instructions and picture:
How to Pair your Plantronics Explorer 230 Headset
Good Luck from Headsets Direct!
1helpful
Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
Linking to UConnect – Required for First-time Use of Each Mobile Phone
To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
• Press the Phone icon button to begin
• After the Ready prompt and subsequent beep, say Set Up Phone Pairing
• When prompted, after the voice or beep, say Pair a Phone
• You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
• For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
• You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
Making a Phone Call
• After the Ready prompt, say Dial
• The system will prompt you to say the number you wish to dial
Making a Phone Call Using Your UConnect Phonebook
• After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
Terminating a Phone Call
To end a call in progress, press the Phone icon button. All calls in progress will
be terminated.
Phone Redial
• After the Ready prompt, say Redial
• The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
Answering or Rejecting an Incoming Call - No Call Currently in Progress
When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
UCONNECT
CHRYSLER GROUP TECHNOLOGY 17
12helpful
2answers
My RAZR V3 won't pair with 2009 Chevrolet Silverado bluetooth
http://www.gm.com/vc/bluetooth/index.jsp?brand=chevrolet&landing=true
PAIRING A PHONE WITH YOUR 2009 Silverado
Before you begin:
To take advantage of the Bluetooth for Chevrolet functionality, you must first pair a Bluetooth-enabled phone to a Bluetooth-enabled vehicle.
Note: If you do not pair a Bluetooth-enabled phone, all calls will be made using OnStar® Hands-Free Calling.3
Some additional tips:
1. You can pair up to five phones with your 2009 Silverado.
2. Your system automatically recognizes the first phone you pair. To use a different paired phone, you must
select it using the "Change Phone" command.
3. Only one paired cell phone can be connected to your system at a time.
4. When the vehicle is in motion, you cannot pair a phone.
5. Pairing should only need to be completed once (unless changes to the pairing information have been made, or the
phone is deleted).
PAIR YOUR PHONE
Set up phone - Turn Bluetooth 'ON':
1. From the main screen, select "Menu"
2. Select "Settings & Tools"
3. Select "Connections"
4. Select "Bluetooth"
5. Select "Setup"
6. Select "Power"
7. Select "On"
Set up vehicle - Enter 'Pairing' mode:
1. Press and hold the Push to Talk button for two seconds
2. Your system will respond with a "Ready" message followed by
a tone
3. Clearly say "Bluetooth"
4. Your system will respond with a "Bluetooth ready" message
followed by a tone
5. Clearly say "Pair"
6. Your system will respond with instructions and a four-digit
Personal Identification Number (PIN); you will need to enter
this PIN on your phone
Begin the pairing process on your phone:
5. Select "Hands free"
6. Select "Look For Devices"
7. Select "General Motors"
8. Select "Yes" to bond with General Motors
9. Enter the PIN code provided by the vehicle
10. Select "OK"
Finish the pairing process in your vehicle:
1. The system will prompt you to give a name to your phone
2. Say a name that best describes your phone (example: Corey's
phone); this name will be used to indicate which phone is
connected
3. Your system will ask you to confirm your name
4. If you confirm that name, the system will respond with the
message: "'<Phone name>' has been successfully paired"
1helpful
Numark cue mixing
to change headphone track, use the cue slider which is located on the right of the control panel above the right chanel treble control and below the cue gain control. chanel 1 or 2 can be selected or in the middle for a mix of both tracks just like the cross fader.
2helpful
2answers
Pairing problem
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Top AT&T Cell Phones Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
