Question about Sewing Machines
Necchi Heavy Duty Sewing machine model 3205FA, bend needle while hemming denim skirt, replaced the needle, but now the needle is not picking up the bobbin thread, any suggestions for me to try???
  • Anonymous Mar 19, 2014
    how to attach zipper foot?
  • Anonymous Mar 29, 2014
    don't know how to adjust stitch lengthon 3205FA model Nechi sewing machine
  • 130 Answers
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Posted on Apr 22, 2009
SOURCE:
Necchi heavy duty royal series. Manuel says 3205FA and 3204FB. I want to know where to oil it. I also need help because it won't reverse anymore. Any advice?
It's an old metal mechanical machine, right? It is probably seizing due to old oil that has dried. Here's my method for "unfreezing" old sewing machines. (You won't believe how good it sounds and how nicely it runs after you've give it some TLC!)
Wheel on right side that controls the needle up and down is very tight...
Jul 04, 2018 | Necchi Sewing Machines
Is pfaff hobbymatic a heavy duty machine?
The term "heavy duty" sewing machine is thrown about loosely lately. There are new machines (including Pfaff, Singer, etc) for sale advertised as "heavy duty," but I would be hesitant to stitch denim jean hems on them. The Pfaff 807, which appears to be an older mechanical, is probably more "heavy duty" than some newer machines on the market. However, "heavy duty" does not mean that you can sew big canvas sailcloth or heavy upholstery projects. A domestic machine (which the Pfaff 807 is) is really meant for general domestic sewing. If you want to sew "heavy duty" fabric, then look to an industrial machine. Remember that frequent sewing of heavy fabric takes a toll on a domestic machine, ie the motor, needlebar, other working parts, thus hastening the demise of your machine and the more frequent need for service & repair.
Jun 17, 2016 | PfaFF Sewing Machines
Where cn i purchase a power cord and foot controller for a Necchi heavy duty model 3205 fa?
http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 29, 2015 | Necchi Sewing Machines
I have a Necchi 3205 Royal series machine. I was sewing denim and it jambed and bent the needle. I replaced the needle and now it won't pull the bobbin thread up. I have tried several different needles...
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
Aug 29, 2011 | Necchi Sewing Machines
Will a NECCHI 535FA sew denim jean material okay?
Use a heavy needle and a product called jean-a-majig from Joann fabrics and you will be fine, just make sure you use the correct needle as this is key
Aug 21, 2010 | Necchi 3101 Mechanical Sewing Machine
The needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Jul 09, 2010 | Necchi Sewing Machines
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
I have a Necchi heavy duty sewing machine, I was hemming a denim skirt, the machine got bound up and now the threaded needle will not pick up the bobbin thread and bring it up. What could be the cause of...
I have the same machine. Try replacing the needle, it could be slightly bent and not be in position to pick up the loop from underneath. A good de-fluff may help too.
Apr 19, 2009 | Necchi Sewing Machines
I have a brother LS2125i it is easy to use, and I am a complete novice- but when I try to sew heavy denim- Like over the thickest part of the hem it makes a very load click nose- and becomes stuck--- is...
It may be the machine, although most machines would have trouble going over the seam. First, use a Denim needle, 90 or 100 and place a "shim" also called a "jean a majig" to keep the presser foot level. If the foot is shifted, the machine will not sew over the bulk. The machine is not real heavy duty, may have problems , anyway.
May 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
559 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
