SOURCE: SD memory card will not format in a Samsung Digimax 301.
I own a samsungDigimax 301, 3.2 mpi camera. When I inserted an SD card in the slot, the screen read " card error". Could you guide me as to dealing with this problem so that I may use the camera to take pictures this weekend? Thanks. Mathew.
SOURCE: hi,just bought a 4gb sd card for my digimax s600
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Testimonial: "hi,thanks for the quick response,i don,t know if it has what you said.it just says on the bottom of the camera..digimax s600 cyber/630."
SOURCE: keep getting card error message while trying to
Is the slide switch in the unlocked position?
SOURCE: I bought a 4GB Memory Card for my Samsung Digimax
Your problem is that your camera only takes standard SD cards up to a maximum of 2GB. The card you have bought is likely to be a 4GB SDHC model. SDHC is a later development of SD; SDHC compliant devices can still use older SD cards, but SD-only devices cannot use SDHC. This is a hardware limitation so there is no way at all to use an SDHC card in your camera.
Note that if your 4GB card is definitely an SD and not an SDHC then it's still incompatible with your camera: very few standard SD devices were ever made with the firmware and hardware to handle the different memory addressing architecture used by the larger capacity card. Some cameras did have firmware updates to allow the larger SD card to be used, but yours is not one of them.
Your only fix is to sell your card (or keep it for another device) and to buy a regular SD card no larger than 2GB maximum capacity.
I trust that my reply has answered your question fully, please take a moment to rate my answer.
SOURCE: I just inserted a new sd card and keep getting a
The D53 uses SD cards, not SDHC cards. You'll have to stay with cards 2GB and smaller.
