Lowrance Lcx 28c Hd 7" Gps Fish Finder Combo With 200 Khz Tm Transducer Logo
Posted on Apr 20, 2009
Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I have a Lowrance LCX 28HD unit with Navionics Premium Hotmaps chip. The chip worked fine last fall. When I tried to use it this spring the unit would not read the chip.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1897
Points
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
How to install the navionics micro sd chip
Hi James
After looking through the user's manual, (see link below) as this unit doesn't have chartplotter capability I think there is no slot for your SD card.
Sorry I couldn't have given you more joy.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/US/MARK-ELITE_SONAR-ONLY_OM_EN_988-10157-001_w.pdf
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Can you tell me how to operate a navionics hotmaps classic on my lowrance lcx16 ci?
It might be possible that you WILL NOT BE ABLE TO OPERATE such maps on your device.
A list of compatible plotters can be found here [in PDF format]:
http://www.fugawi.com/web/products/plotterfacts.pdf
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
Lcs-20c GPS slow with HotMaps Premium 09 card
Does the image come back by itself if you slow down or stop and wait? If not, make sure you are not leaving the coverage area of the chart you are set to. In the LCX-20, that Navionics chart is split up into several sections, if you have one section selected and are on the border and then leave that area, the map usually goes all white depending on your zoom level. If you are on a border like that you will have to learn to quickly switch the charts from the MAP DATA menu.
If the map does catch up when you slow or stop, and just can't redraw fast enough...
Make sure the LCX-20 has the latest updates which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
These updates often add additional Navionics support.
Most likely though, this is just going to be the way it is with that particular map and the LCX-20. If you zoom out it will be much much better. So if updating doesn't help, zoom out. Experiment to see how close you can be zoomed in while running above 20mph. If you can get a good zoom level to where the map can keep up and you can still see the information you need then you should be good to go. If not, use the LakeMaster card or go get a different mapping option...or upgrade your display unit.
Lowrance HDS-5 won't load Navionics
You need to wait for a fix from Lowrance on the HDS units. Supposedly, a new software update is planned for May 15th 2009 to address this.
May 05, 2009 • GPS
I have a lcx 28c hd fish finding sonar and mapping gps
I've had several similar units, and used them with Navionics HotMaps Premium series chips. You must select Menu. The "Browse files" to access the MMC card option. Once the selection screen opens, choose which card or file you want.
FYI...All of Lowrances HD models come preloaded with pretty much every major lake and river in the US.
Lemme know if this helps...
Triton72
Top Lowrance Boating Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
