Frigidaire FRU17G4JW Refrigerator Logo
A
Anonymous Posted on Sep 27, 2013
Freezer door lost its magnetic seal - Frigidaire FRU17G4JW Refrigerator
1 Related Answer
Anonymous
  • 212 Answers
  • Posted on Jul 02, 2009
SOURCE: Replaced magnetic seal on freezer and door still
depending on where the gaps are your hinges are warped. losen up the hings bolts and adjust hinge then hold in place and retighten bolts
1helpful
Fridge door Magnet does not work
do you mean the door seals,if so you may need new ones or you have lost the vacuum in your ff, they are not magnets they feel like it but it is vacuum sealed,,try a ff second hand shop
2answers
Door was not sealed tightly for about a day resulting in some frost inside freezer. Door appears to be closed but door ajar light is still lite and alarm is still beeping. What do I need to check?
The door seal has a magnetic property to it. Until the freezer gets to a certain degree the magnetic porperties of the door seal dont react properly. Make sure the door seal is properly adjusted. If the door was left open it could have semi warped the door. This gets corrected when temp drops to correct temp. Reset freezer by unplugging and waiting for a few minutes. If problem persist contact appliance technician.
If you have any more questions you can comment me back.
Every time the top frig door is closed the bottom freezer door opens sometimes only 10 or 15mm so that the alarm does not detonate. The reverse also happens, ie top door opens when the bottom door is...
There is an air duct that connects the fridge to the freezer. When the opposite door is closed air is trapped and forced out the other door pushing it open.
The door seals contain a magnetic strip that hold the door to the fridge, these magnetic strips have lost their strength, to test this use a shhet of paper. Open the door, place the sheet of paper across where the door closes, shut the door, then slide the paper out. If the paper comes out without any resistance then the door seal needs to be replaced.
Freezer door pops open when the Refrigerator door is being closed
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
When we close the refrigerator door the freezer door pops open. It seems like a vacum problem?
1helpful
2answers
Every time the refrigerator door is closed, the freezer door pops open. How can we better secure the seals?
Freezer won't stay shut
If you want a part number for the replacement door gasket please provide a complete model number here so I can give that to you or you can look it up yourself at www.searsdirect.com You must have your model number. (sample 110.XXXXX etc)
The magnet is inside the door seal itself. If the seal is damaged replacement is your only option.
Thanks for using FixYa!
Kelly
2helpful
2answers
THE SEAL ON THE FREEZER DOOR IS NOT HOLDING, CAUSING FORST TO FORM IN THE FREEZER TO THE POINT THAT THE FREEZER STOPS WORKING.
Well without knowing the model or configuration, (upright, or chest), there are only a few possibilities. 1 - if the seal is magnetic, then its lost is magnetism. 2 - if it has electric door seal heaters, then they are defective, and need to be replaced. 3 - if the seal itself is damaged, ripped or torn then the air penetration will cause this, espescially if the surrounding air is humid. 4 - If it's an upright, then the unit might not be leveled properly to allow sufficient closing pressure.
1helpful
REPLACEMTN MAGNETIC DOOR SEAL FOR FREEZER NOT
freezer needs to be down to temp with door shut for about 1hour to build up vaccum
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
