SOURCE: NO SIGNAL PROBLEM
Please check whether the monitor is set to the correct settings. If you feel its incorrect, most LCD/TFT monitors come with an auto set up button which will restore the display to one that usually works. In case it still doesnt work, you might need to connect your pc to a different monitor and check the display settings. You could also try to download the drivers for this monitor and then re-connect the monitor and see if it works.
SOURCE: i have an asus lcd
What happen if you use the VGA or the DVI ports? Do you get the pictures OK on the other two ports. Only one port at a time can be used. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
SOURCE: asus monitor vw224u stopped working, found was
Try pressing the S/A button to change input sources.(the button on the far left on the front of the monitor) Chances are the cable got unplugged, then the monitor when into analog mode and its now stuck there, because many monitors default to analog.
