go here for expert help on Villager & Quest
http://groups.yahoo.com/group/villagerquest/
Item
Part Number
Description
40 Timing Chain/Belt Teeth
Camshaft Sprocket , Front
43 Timing Chain/Belt Teeth
Crankshaft Sprocket
5
6268
Timing Chain/Belt
6
6256
Camshaft Sprocket , Rear
Removal
Drain the cooling system. Refer to Section 03-03 for the procedure.
Disconnect the battery ground cable (14301) .
Remove the generator drive belt, water pump and power steering pump drive belt, and the A/C compressor drive belt (if equipped). Refer to Section 03-05 for the removal procedure.
If equipped, remove the three A/C compressor drive belt idler pulley bolts and the A/C compressor drive belt idler pulley.
Remove the upper radiator hose bracket bolt.
Loosen the two upper radiator hose clamps and remove the radiator hose bracket bolt. Remove the upper radiator hose (8260) and the upper radiator hose bracket from the vehicle.
Remove the water bypass hose (8597) from between the thermostat housing and the water hose connection (8592) .
Remove the main wiring harness from the upper engine front cover (6019) .
Remove the eight upper engine front cover bolts and the upper engine front cover .
Raise and support the vehicle.
Remove the RH front wheel and tire assembly.
Remove the four RH outer engine and transmission splash shield bolts and two screws and remove the RH outer engine and transmission splash shield (6775) .
Use Strap Wrench 303-D055 (D85L-6000-A) or equivalent to hold the water pump pulley (8509) while removing the four water pump pulley bolts.
Remove the water pump pulley from the water pump (8501) .
Remove the crankshaft pulley (6312) . Refer to the procedure in this section.
Remove the five lower engine front cover bolts and the lower engine front cover .
Ensure that the timing marks between the crankshaft sprocket (6306) and the oil pump housing line up.
NOTE: The directional arrow is necessary to ensure that the timing chain/belt (6268) can be reinstalled in the same direction.
Loosen the timing chain/belt tensioner nut.
Remove the timing chain/belt .
Installation
NOTE: Ensure that the timing marks on the camshaft sprockets (6256) and the seal plate are properly aligned. Ensure that the timing marks on the crankshaft sprocket and the oil pump housing are still aligned.
NOTE: A new timing chain/belt has three white timing marks that indicate the correct timing positions of the camshafts (6250) and the crankshaft (6303) . These marks will help ensure that the engine (6007) is timed properly. When the engine is properly timed each white timing mark on the timing chain/belt will be aligned with the corresponding camshaft and crankshaft timing mark on the sprocket. Because the white timing marks are not evenly spaced you will need to refer to the following illustration for proper timing chain/belt placement. There should be 40 timing belt teeth between the timing marks of the front and rear camshaft sprockets and 43 teeth between the timing mark on the front camshaft sprocket and the timing mark on the crankshaft sprocket .
NOTE: Verify that the camshaft timing marks are aligned with the timing marks on the seal plate, and that the crankshaft sprocket timing mark is aligned with the timing mark on the oil pump (6600) .
Install the timing chain/belt starting at the crankshaft sprocket and moving around to the camshaft sprocket following a counterclockwise path. Do not allow any slack in the timing chain/belt between the timing sprockets. After all of the timing marks are matched up with the timing chain/belt installed, slip the timing chain/belt onto the timing chain/belt tensioner .
