The player will play 1 out of 10 times of trying.
I have sprayed the can air and tried the Disc Cleaner nothing helps.
Is there a fix for the loading error
The disc cleaner is not exactly clean your lens! much better to open your DVD and you clean the lens with 100% cotton or cotton buds then slightly touch your cotton to lens in clockwise to remove the dirt!
Usually, you either have dust on the laser, so it can't see anything, or you have something on your disc (or damage to the inside part of the disc, which tells the player where all the files are). You can try cleaning your disc, but if you've already tried more than one disc, you might be able to find a CD or DVD cleaning disc at an electronics store. If your DVD player plays CDs, either one might work, but if it doesn't play CDs, then you will have to look for a DVD cleaner. As a last resort, you could try getting a can of electronics dusting spray (don't use a vacuum, as the static from a vacuum can damage electronics) and use several quick sprays, while the DVD player is unplugged. Give it a few minutes to dry out, then give the DVD one more try.
if you have a dvd lens cleaner tried to clean it first. if still no disc error, look for the spindle motor if it is rotating while you are playing with a disc. if not, check for motor worn out at this time you will need to remove the cover to access the internal part.
Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
You probably have a dirty reading head.
Try cleaning it with a DVD cleaner disc. (you can get them from wal-mart)
If that doesn't want to co-operate after trying to use it three or so times open the drive, remove the disc and shoot some canned air in the slot where the disc holder is in a sweeping motion.
Then try the cleaner disc again.
If it still won't work after that you can either buy another one or take it to someone that understands how to take things apart and have them clean it manually. (gentle singular motion with a cotton swab)
If that doesn't work have them adjust the resistance pots on the laser head a little lower (this would amp the laser up a little)
I should mention that if they aren't sure what to do and they lower the resistance TOO much then your laser will indeed burn out quicker.
It's unable to read the source disc.Try using a comerically recorded disc.Try several different ones.Use a disc cleaner to clean the laser if all else fails
The lazer beam of the disc has a micro dust that need to remove. You can try to use the cd cleaner. If nothing happen , you need to open the disc and spray the lenses with soft air.
I had a similar problem...the machine, which had been great up until then, started to be very fussy when loading a disc; using a lens cleaner did not help at all.
I opened the disc tray and used a can of "air duster" with the straw attachment blowing in lots of air into every little nook and cranny that I could reach, especially in and around the actual lens area. The liquified gas under pressure must have been too cold as, at first, there was no improvement whatsoever when I tried playing a disc. However, the next day the player was working perfectly again.
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
