SOURCE: unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
SOURCE: Can't connect my ps2 with my rca truflat
well if u have a VCR or DVD play with u can run it though the the vcr first then back up to the TV makes sure u have the correct channel on and if that is not the case u may have to buy a small switch box (wal-marrt) Cheap to add more AV in puts.
Let me know if this works!!
Thank U jayson
Please feel free to rate my suggestions.
we depend on your votes!!!
SOURCE: my front panel is locked to my RCA 14F514T ...how
COMO DESBLOQUEAR EL PANEL DE CONTROL DE MI RCA
SOURCE: rca 20F420T
I had the same preoblem with my rca model 27f520t truflat tv. I used a universal remote. When I first tried with the universal it would not work for me. The remote would turn the tv on and pull up the menu but the channel up or down and volume up or down would not, the light was flashing. I pulled up the menu and pulled a battery out and put it right back in and the menu stayed up and the light stopped flashing. I was able to go to preferences and turn off the fpa lock. good luck this was difficult to figure out and had me very irritated.....
1.
Hold down MENU
on the remote and VOLUME DOWN on the TV it's self at the same time for at least
4 seconds. The set won't say so, but the lock will be unlocked
2.
Hold down the 0
on the remote and the VOLUME DOWN buttons on the TV its self at the same time
for at least 4 seconds. The set won't say so, but the lock will be unlocked
3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds.
4.
Hold down GO
BACK on the remote and MENU on the front of the TV at the same time for at
least 4 seconds.
5.
Hold down EJECT
on the front of the TV and the MENU button on the remote at the same time for
at least 4 seconds.
Depending on the
model, one of the methods should unlock the V-chip. Now, if desired, you can change
the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS,
or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
