Jenn-Air JJW8230D Electric Double Oven Logo
Posted on Sep 20, 2007
Error Code F8
Okay, here's what happened. I attempted to use the self-cleaning feature on my double wall oven. About a minute after the process began, I decided to cancel the process. I have since been receiving an F8 error on the display and a constant beeping sound from the oven. The only way to stop the beeping is to press the "clock" button. However, the F8 error remains on the display. If I press cancel again, then the fan turns on, the over door locks, and two minutes later the beeping and F8 error reappear. I have no idea how to get everything back to normal again. Please help!
  • 7 more comments
  • Anonymous Dec 05, 2007
    My issue is similar to Baking Girl. Dacor oven, set for self clean, starts to beep and F8 error displays. Only way to shut it up is to hit the breakers. Breaker does not reset the F8 and now oven is on the fritz. Please advise!
  • Anonymous Jan 05, 2008
    Same problem F8 appears. Powering oven off does not fix it. Buttons seems to have no effect.
  • Anonymous Mar 01, 2008
    I'm trying to clean my lower oven (Jenn-Air WW2780-C) It turns on fine, but about 2 minutes into the cycle it beeps and flashes F8 on the wall pad. What gives?
  • roachrp Oct 24, 2008
    same prob a couple years ago. technician tried a new board, didn't work. he managed to rig the system so i could still cook with it as long as i didn't press the "clean" button. well... guess what, i accidentally pushed that button instead of "bake" and now the F8 with all its beeping, locking, and fan issues has returned and tech will not return my calls.
  • Anonymous Mar 14, 2014
    JA F8 E0 Error code will not complete self cleaning
  • Anonymous Mar 18, 2014
    Shows "lock" in green, four nonsensical symbols separated in the middle by a colon, degree symbol with "c" for Celsius, and "delay" in red. Only the bake, timer, and cancel buttons will work; all other buttons double-beep. How to reset the oven to clock display, please? Thank you!
  • Anonymous Mar 23, 2014
    microwave and over work fine. once the preheat is done or the microwave completes its cycle, the normal 4 beeps is now just one continuous beep and doesn't stop until you press end. this is a wall unit model GMC305PD. Everything else is working as normal.
    I have a wall unit whirlpool model GMC305PD that works perfectly fine with no error codes displaying. when the microwave completes its heating cycle it normally beeps 4 times. now it is just 1 continuous beep and you must press stop for the continuous single beep to stop. same when oven is used. happens on preheat for oven as well. what could be the issue? can the beeping be turned off?
  • Anonymous Mar 26, 2014
    ALONG WITH THE FAULT CODE THERE WAS A SMALL "OK" IN THE RIGHT HAND CORNER. I PUSHED IT THE SCREEN WENT BACK TO ITS NORMAL TIME DISPLAY THE OVEN COOLED DOWN A LITTLE AND UNLOCKED ITSELF THE OVEN DID NOT CLEAN
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8499
Points
2answers
What does an f8 code mean on my Frigidaire self cleaning oven mean and it beeps?
cool down before it opens if you started the clean timer, f8 code, might be that its on a timer
Ned's to know witch relay to replace wich f8 problem
Hi there! Typically for such an error code, F8 or F80, there is a communication error between the UI (User Interface) and the control board (often the microwave control board). Yes you have a microwave control board in a double wall oven. This will require either the main control board or the UI board being replaced by a professional for safety reasons. I would suggest to contact a professional that partners with your manufacturer. Contact your manufacturer first to see if there are any known issues or a limited warranty for your model.
Cannot use self cleaning feature on Meile double wall oven. Get the same error message on the top and bottom oven. A giant F and fault 09.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
2answers
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
1helpful
F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
3helpful
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
2answers
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
