I have a sanyo s1070 digital camera.Everytime i turn on my camera the screnn will only show lens error 0x4110000. How can i fix this?
SOURCE: my sanyo vpc-e760 digital camera is showing lens error:22 what do i do
well i have a SANYO camera and every time i cut it on it cuts on a little bit and i see it and it sais lens error: 308 what does that mean?
SOURCE: sanyo s1070 digital camera will not download pixes to pc.
have you tried taking out the memory card and using a card reader instead? some cameras would have dedicated software for the computer to read them but most will be plug and play using a USB or firewire based card reader.
SOURCE: Problems with Samsung S1070 Digital Camera lens
Thankyou,
The lens most likely has a safety eject system. There should be a button or two you can hold or press at the same time if there are two, then try to gently push it out in the position it comes out from. Or if it is a screw type. There is should be a holder/cover you can remove. This should help. Hehe
V :)
SOURCE: My daughter's Sanyo VPC S1070 digital camera shows
We have the same problem with our sanyo...does anyone know the manufacturers number...walmart would not take it back cause we threw away the box..so we are stuck with a camera that does not work and spent alot of money on it. any suggestions???
SOURCE: Lens Error: 0x12110000 when previewing pictures in camera.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
