SOURCE: setting the date and time
All you have to do is:
Go to the main attendant phone, press Trans/Prog, then 0 for attendant, 4 for time and 1 for change time /date. Enter in the correct date and press OK, then enter in the correct time (in 24 hour format) and press OK. The time and date should now be correct!
SOURCE: Telstra F4100 Dect Cordless Phone Problem:
i subscribe to bt for caller id but has suddenly stopped working and just comes up call. do i need to get new batteries?
SOURCE: Set not ringing
When you say you are the one responsible for the programming, are you referring to programming the "physical phone" or the PBX and line cards and system functionality?
You should have an extension on your phone. Has that extension for example 222 been translated at the PBX to ring on a direct number -> (xxx) 555-1222
Or by what you are describing, you are more looking at having "shared lines" that ring in multiple locations simultaneously, and once picked up somewhere a "line lock" should be in place?
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: My phone won't quit ringing
Keep looking under Terminals and Sets for your extensions. Lines either Appear or Appear and Ring.
Carl
