ok where can i get a chager i went to amazon and they keep sending me dirrent one for a 2ok where can i get a chager i went to amazon and they keep sending me dirrent one for a 2
You can't post conmments that contain an email address.
Availability of the JP5 tablets varies depending on the state, facility and other ... Includes accessories like earbuds, screen protector and batteries or charger ...
It is more likely either the cable or your are not using a Samsung charger for one. If you let their tablets get below 1% only a Samsung charger will recover the battery. In theory it should not be require but I have tested it a dozen times and every time switching to the Samsung charge for the next few charges makes it so any USB charger (under 2 Amps) will then work again.
Yeah, I think Samsung uses the standard 1 years warranty for everything. They are not exactly Weber or anything and do not provide long warranty periods.
Did you allow the battery to run down until it was completely drained?
- If so then try the following;
Watch this video (link below). You should only remove the back cover, disconnect and reconnect battery cable. Disregard the rest of the video as I could not find one doing ONLY what you would need to do. Follow the instructions to remove the back of the tablet then disconnect the battery cable(careful not to damage the circuit board), reconnect the battery cable, and replace the back cover. Connect the charger, within a minute the screen on the tablet will pulse/flicker which is good news, allow it to charge a while, turn on the device, turn off the wireless wifi, click the power button to turn the screen dark again, and allow to charge for another 6 hours or till fully charged (when not connected to wifi the background processes will affect the charge time, on a weak charger it may not even charge like from an usb port on a computer).
Again, you should only be concerned with the video up to about the 1 minute and 15 second mark. You only need to disconnect the cable then reattach it. ONLY DO SO if you are comfortable doing so. If you have never worked on electronics before or are uncomfortable find someone to do it for you.
Either the battery or the charger is done for. If you have family or a friend with the same unit, you can verify your charger and your unit with their equipment.
There are a couple of common problems that can cause bad charging:
Bad charging cable - try a new cable
Bad charger - try a new charger, or try plugging it into a PC USB port overnight with the PC turned on
Charger is not the right charger for your tablet - Samsung devices are known for being picky about what charger you use. If you don't use the original charger that came with the device, or a Samsung charger made for your specific tablet, you will have trouble.
A bad/broken charging port on the tablet - this is not something you can fix yourself. You would likely have to return it to Samsung for repair, or find a local repair shop.
I got my tablet with a charger but after some time it got damaged.. NOW I USE THE MINI-USB cable to charge it.. you can use an adaptor like the one that comes with the Samsung galaxy cellphone and use the mini usb cable with it.. Hope you understand my mess.. good look..
