SOURCE: 1. Start Outlook. 2. On the Ribbon, click
If you cannot fit your PST file backup on a single drive please try choosing "Compressible Encryption" as the format to save as. This will reduce the amount of space needed to back up your PST file.
If it still won't fit then try backing up to a network drive.
Please let me know if this helps and rate my answer.
Many thanks,
Chris
SOURCE: Bcc emails on Outlook 2010
Sounds like your Email has a set up issue. Check the Receive email setups under options. Make sure that you are able to receive BCC emails.
SOURCE: Microsoft Office Outlook
Run Outlook from a command line with the /cleanprofile switch appended to the command.
To find the correct command line, right click on a shortcut for Outlook and go to Properties. Copy the information in the Target field and Paste it to the command line. If there is already a command option, remove it and add /cleanprofile after the closing quotation mark. (Add a space before /cleanprofile)
For example, go to Start: Run. . and enter something like "C:\Program Files\Microsoft Office\OFFICE11\OUTLOOK.EXE" /cleanprofile .
Then add a new profile. Be sure to check the check box for "Set as default profile". Note: You cannot see this option unless you click on the "Options >>" button.
This should fix the problem.
SOURCE: How do I easily backup email files in Outlook 2010
Open Outlook, click on file in the top left hand side. Select Import and export. Now select export to a file and click next. Now select the file type you want save as (I mainly use a pst file and its the most common) and click next.
Now select which files you want to back up, for example Inbox, send items, contacts etc and click next. Now Click on browse and navigate to the external drive or save it to your desktop and copy the files to the external later on.
You can back up all of your emails this way just change the name of the file from backup to Inbox etc.
Regards.
Testimonial: "Excellent advice, though one step left out - that you need to click on Options and then Advanced to reach the Export proceess in Outlook. Thank you."
SOURCE: I am trying to start the microsoft outlook
Advanced Recovery utility designed to repair and recover corrupt emails from Microsoft Outlook.To know more visit and download trial version fro:- Outlook PST Recovery
Well equipped with search option to quickly locate your PST Files, Kernel for Outlook PST Repair is the most efficient email recovery tool that provides complete recovery solution for damaged, deleted or corrupted PST files. To download the tool visit http://www.pstrecoverytool.net/
