Seiko DPU 414 Matrix Printer Logo
Gerald Mann Posted on Sep 26, 2013
When using the printer connected to a device tome of the data in the middle of the line prints as 1 number; however, when comparing to the device display the numbers dont match. When doing a repeat print through the device, the data now mayches. Any potential causes to look at?
vinay4mlr
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Sep 26, 2013
vinay4mlr
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
2009
Points
31
I feel it is totallyprint driver problem. driver you are using is not matching the printer. install proper driver provided by printer vendor
Testimonial: "For last several years it has worked properly, happened 3 of last 40-50 times used"
2 Related Answers
Anonymous
  • Posted on Oct 24, 2011
SOURCE: Smart LabelPrinter Seiko 440
These printers are designed to use only the labels with the ink bar on the back. the ink bar is the guide that tells how much to print.
Anonymous
  • 13 Answers
  • Posted on Feb 03, 2012
SOURCE: DPU-414 model Thermal Printer, When ever i switched on the equipment the printer always print the 2 lines of Junk data are Either * or ? what could be the reason
the logic board of printer is defective. you can go to electronic shop repair.
2answers
I accidentally deleted connection when trying to get rid of a Built up printing queue! Having done anything manually, only on screen! Help please
Turn off the printer first. Try unplugging the cable between your computer and your printer and re-plugging it back in. Then turn on your printer and hopefully it will allow you to add the printers operating software which is known as a print driver. Good luck !
This printer is connected to a device that on occasion will print data in the middle of the line with incorrect values when compared to the display. When the device is told to reprint, the data is not...
please check the DATA cable and printer driver installed in the system. these are two things often responsible for junk printing.. what kind of printer iit is ? laser ? inkjet or Dot matrix?
My printer is not working properly. On the test page, not every line prints clearly.....faint and grey compared to other lines. Lines 1, 4, 8, ll, 14, etc. prints very light compared to the other lines. ...
sounds like your heads are all gummed up with dried ink.Is this a older printer or previously used if so run the cleaner that should have come with your printer software. keep running it until clean or bring it to get cleaned.
Samsung STP-103 Thermal Printer will not print lines correctly
Wow, serial communications still in use. Naturally, both units have to use the exact same protocol N81 for instance, so make certain the sending unit is set to the same, then check the cable to verify that the appropriate pins are connected and or crossed. I believe your symptoms can be caused by using hardware handshake and having pins 6,8,20 (20 only if a 25pin connector) shorted on the printer end. If possible, you can try switching both devices to software handshake.
2helpful
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Printer has good power connection but no response at all. i know power connection ok because page number light glows on printer
Install its driver. Or in printing que set the lexmark 2600 as the printer to be use. Then test print. Check its data cable.
If this doesn't help leave a comment so we can device another solution
I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
Printer stopped printing and says its off line!
HI,
Im Rizwan from India, i would to tell u to check few things that will resolve this problem
SOLUTION:
NO 1: Check the Connection and power
1.Check the USB cable and the power line to the printer.
2.unplug and replug the cables at the PC an printer end.
NO 2:Check the printer status in control panel.
1.Click start - >Run.
2.In the run window type "control" (without quotes).control panel will open.
3.In the control panel, look for printers and fax and check the printer icon.
4.If printer icon says Offline, Right click on printer icon and select "use printer online"
5.Try printing, if it didnt print follow step NO 3.
NO 3:Restart the USB Composite Device.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET 720C
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Try printing Now, if it didnt work please response.
Thank you
Rizwan
[email protected]
Top Seiko Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
