Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
Posted on Apr 19, 2009
Toilet bowl is clogged
How do I unstop it?  Plunger will not work.
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on May 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
2813
Points
7
Go to Lowes and get a power plunger (it shoots a blast of water directly at the clog) or get a plumbers snake and work the clog out. Follow up with a liquid Plumber or Draino unless you have a septic tank. Good luck.
  • Anonymous Oct 29, 2013
    I also had a similar problem with a clogged toilet in Prescott AZ. Nothing worked! Not the plunger, not that drain-o stuff, nothing! It was so frustrating!
3answers
How do toilet plungers work?
If a plunger doesn't work, use a snake. Plungers work by forcing water down the drain. As the name implies...
Feb 18, 2015 • Home
Plunger to fit Kohler bowl
So there is pressure when you push, and suction when you pull. Plungers are more effective when pushing water instead of air because water doesn't compress. ... Thrusting the plunger moves column of water like it was a solid piston and applies the entire force of the thrust against the clog.
Wand will not launch when seat is activated
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism . Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 • Home
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
Nov 25, 2013 • Delta Home
Water over flowing from the toilet
It must be clogged. Try using a plunger first. If thayt doesn't work, consider using a "toilet snake". Simply place the end of the flexible cable into the toilet bowl and begin unwinding. The cable will extend round the bends in your trap way dislodging any clogs as it goes. If you come to the point where you feel some resistance, you will need to rewind the cable back into the bowl and remove anything that comes up with it. Repeat this process until your toilet runs clear.
May 18, 2011 • Home
When I flush the toilet, the bowl feels with water. It will not empty the bowl.
You have a clog in the toilet or in the piping....
Often this can be corrected by using a toilet plunger... they can be bought at any local hardware...
if the plunger don't work, then the toilet auger is the nest step...
If you cannot get it going with that, then you need to call in a professional guy to open your piping...
heatman101
Jan 14, 2011 • Home
2answers
Kohlers Memoire two piece is clogged. == My plunger has a round opening and it does not create a seal - the toilet bowl is oval. Is there a special plunger or some such.
Many plungers have an inner flange that is used for toilets in particular, make sure to pull that out. Even in most case a forceful use of the plunger will get some results so with this flange and enough elbow grease you should be able to acheive some results
1helpful
2answers
Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
