Hi, How Can I Reset error in my wash machine Bosch Maxx WLX20362PL http://www.electro.pl/pictures/products/big/26652_3.JPG Machine show F 21 error, but i replace new motor brushes
Error code reset on Classixx 6 1200 Express
The post above is correct, just missing one detail, see below;
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position. Wait for Error code to flash
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position (Drain position)
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off. Wait 5 seconds
When you turn it back on it should have cleared the error code.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
When your turn it back on it should have cleared the error code.
Testimonial: "look on the photo, that Wash Machine have Knob with 15 position...and where is 7 o'clock position ? I Can't set Knob Between two options ;/"
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
SOURCE: changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
SOURCE: Bosch Maxx Instruction Manual
F:16 - Doors are not properly closed. Check the doors are closed with no obstacles.
F:17 - Water is not running. Check the tap, hose and filters. Also water pressure can be low.
F:18 - Too much water remaining. Stop the drying program and start Spin program. Otherwise something is bolcking the water exit from the machine.
