SOURCE: Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
SOURCE: Husqvarna Rose embroidery unit stopping mid picture.
Try another design. If the problem continues, it may be time for a service call at an authorized husqvarna viking dealer.
You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
The tension control has a screw on the inside wall of the sewing machine. It probably came loose and will not allow the tension to pull taught. If you take the top off you can look down to where the tension knob is coming from. There is a screw that you can tighten while you push forward on the tension knob while set to zero. Keep the presser foot up.
