Not answer my question is what is the solution for wall mounted unit Model number 18cith1 has error H4 this error meaning here mention system protection.
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
That copier is kind a old. The H4-00 is a fusing error code. The problem is that the fuser is not heatting up right. Mostly it is that
the fusing lamp is broken or the thermal fuse is blown. It will not reset untill the problem is resoloved
