I have a godrej locker at home , but i locked it twice and now the message comes secure . now how do i open it. the code is same but it was locked twice and so the message came as secure - good.
now i can't open it
Low battery voltage will allow display to work but not enough power to operate release circuit which requires more power - try new high energy batteries.
Press CLEAR(*) key twice, display will show “PROG”, then enter original master code (factory preset is 800000), display will show “NEU”. 3. Enter the new 6 digit code of your choice , the LED display shows “AGAIN”, then enter the code again and press LOCK(#) key to confirm. 4.
To unlock a high security safe without breaking its integrity will be a tough job for you but i guess the following link may provide you with some assistance: http://www.youtube.com/user/harisonkeys?feature=mhee
You can set up a security code to lock your Nokia 6288 keypad in case a thief tries to call from your stolen phone
Published on Mar 14, 2007
You can set up a security code to lock your Nokia 6280's keypad in case your phone opens in your pocket and calls one of your contacts, annoying them and potentially running up a huge bill.
The code will also stop a thief from using your stolen Nokia 6280 to run up a huge phone bill before you can alert your network provider.
To set the security code, click Menu > Settings > Phone > Security keyguard. You'll be prompted for the Security code. By default this is 12345. Enter this and press OK. Select On and click Select to see the message 'Security keyguard activated'.
Now when you slide your phone shut and press Lock, you'll see the message 'Keypad locked with security code'.
When you slide it open, you'll be prompted to enter the security code. Type your code and click OK to activate your keypad.
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed'. Hope this helps.
