Posted on Apr 19, 2009
Office Jet pro L7500 paper jam - how to open printer?
Paper jam in printer- how to open the printer - HPoffice pro L7500
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 18, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
2689
Points
21
Hi!!! in your case my advise to you is to open the duplexer located at the back of the printer and look if there's a stock paper or any material that can cause paper jam to your printer.
  • c21leila May 02, 2011
    this grandmother thanks you. My manual has no reference on how to remedy.
    Thank God for Google.
    Nana lee
Hp laser jet pro 400 my question printer massage:-open door and clean jam & jam in cartridge area what is the solution
Chances are you have a paper jam. Remove the toner and open the back door and check for a paper jam. If you had a paper jam previously and had the paper tear on removal, look for small strips etc.
Hp officejet pro paper jam when there is not one
Type in your search engine How to fix a printer jam in an HP office jet pro YouTube
Hp laser jet cp1525nw false paper jam
All I can say is check the paper Jam sensor for particles of paper that it is sensing as a jam.
Hp office jet l7680, paper jam, however no visible paper remaining, jam indicator still flashing.
If the printer shows ready and after you send the print or copy job it gives you paper jam, then the problem is with the pickup roller.
Let me know and I will help you further.
How do i install on windows 7? HP OFFICE JET PRO L7500/L7600/L7700
there are no drivers available for hp printer on windows 7..
so better use windows vista or everyone's favorite windows xp to connect your printer...
When trying to use the scanner to make a copy of a document. The paper jammed, how do you remove it? It said on the glass window to remove the back where the ink containers are. I did that but I cannot see...
There are possible 2 places for the paper jam, either the Feeder has jammed or from the input tray.
For Feeder, you just have to open the feeder from the top and see if there are any pieces sticking in.
Else, you can open the print head cover and look for pieces of paper jammed in it.
Another place you may see is by removing the rear of the printer, it is called a duplexor which can be taken off easily. You may find some bits of pieces in rear of the printer.
To avoid getting another jam, try to keep the paper in a cool and dry place. If the paper absorbs any humidity, it starts crumpling which results in paper jam. You can also try fanning the papers before putting in a bunch and use a recommended paper for the printer.
Hope this helps.
Cheers...
3helpful
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Paper jam in HP 4255 office jet all in one printer
the paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
k24674
ADMIN Andrew
ADMIN Andrew
