Need help fitting a clutch on a VW GTI Golf
undo centre wheel hub nut 30mm/32mm, socket. undo lower wish-bone outer bolts, disconect battery,/remove starter motor,/remove transmission mounting bolts to body frame ,/ remove all surrounding bolts around bell housing transmission,/ remove clutch cable from transmission,/ remove drive shafts from centre hub and transmission,/ make sure car is standing on axle stands at front of jacking points,/use a trolley jack to suport engine sump with a piece of wood,/ slide transmission away from flywheel,/lower transmision on floor,/undo all clutch plate preasure bolts 10mm,/remove thrust bearing located on centre transmision shaft ,.also make sure if fitted speedo cable needs to be removed.new clutch plate should indicate flywheel ,without fitting clutch plate wrong way round/otherwise transmision will not bolt to engine block.,
